Question about Sony Televison & Video
Picture/video is choppy/stutters when playing. Kind of like it's jumping from frame to frame
  • 1,557 Answers
Clean the laser using a lazer disc cleaner not only does the disck get dirty but the lazer too when its too dirty it wont read the disc -- disc error
heres a piture of one you get them from electronics shops
Picture/video is choppy/stutters when playing. - sonicboomele_8.jpg
Posted on Jan 02, 2011
Choppy video play back
if the picture is choppy, the head must be tested , first you try to clean it with a cleaner cassette several times, if picture is not getting clear the head maybe faulty, change it.
Nov 06, 2015 | JVC 32x Optical Zoom MiniDV Camcorder
I have a samsung wb100. After I transfer video to my pc via usb, the video is choppy and stutters a bit. I thought at first it was my editing program, but it turns out that my original clip is messed up...
It sounds like your connection lead could be faulty. Or that something is interfering when you transfer the file. If the file is on an SD card, try taking out the card and put it in a SD to USB card stick.
Oct 19, 2013 | Samsung Wb1000 Digital Camera
Choppy internet connection
If you are a frequent viewer of Internet-based video, then you know how frustrating it can be when streaming video doesn't play correctly. When a video is described as being "choppy," it can mean several things, including out-of-sync audio, stuttering frame rate and/or inconsistent stream speeds. However, although this term can mean several things, there are several ways to address all of these issues at once and help make your video viewing experience a bit smoother. Empty your Internet browser's cache and temporary files. Click the "Tools" menu and then select "Clear Private Data Now" (in Firefox) or "Delete Browser history" (in Internet Explorer). When you browse the Internet, your browser collects information from the websites you visit and carries this information as temporary and cache files. Too many of these files can bog down your computer, so delete them. Disable hardware acceleration. Open your computer's "Control Panel" and then click "Display." Select the "Settings" tab, click on "Advanced" and then click "Troubleshoot." Drag the hardware acceleration slider all the way to the left. This procedure can help reduce the strain on your processor, which can lead to choppy videos. Add virtual memory. If you are using Windows Vista or 7, you can add extra RAM to your computer by plugging a USB mass storage device into the computer. The operating system will automatically convert the unused space into RAM. Run your disk defragmenting utility. Click "Start" and then select "Programs." Click "System Tools" and then "Disk Defragmenter." This utility will eliminate the fragmenting of files, which could be taxing your processor. Stop Slow Streaming Video http://www.delete-computer-history.com/slow-streaming-video.html
Feb 24, 2013 | Computers & Internet
Samsung PL200 choppy, jerky, stuttering, not smooth video. how to fix?
Update the video codecs for the video editors you use on your computer.
Mar 13, 2017 | Samsung PL200 Digital Camera
I just got my Xacti CS1 and after I shot a couple of test videos, I checked the playback. On the camera screen, playback is flawless, it's quite great, however, when I play the videos back on my macbook in...
http://us.sanyo.com/dynamic/product/Downloads/VPC-CS1_OM_English-6223243.pdf
p.60 of the manual describes different recording modes with lower resolutions (1280x720) pixels and lower frames per second (30fps).
I would choose from the menu to record in a lower resolution and lower fps mode so that the quicktime program can display the video at a good rate for you.
I don't know what kind of macbook you have, but usually such problems are due to the older macs not having enough speed to display high definition video with all its data all at once.
I used to have problems a few years ago, before i upgraded my hardware on PC's, with choppy video that was High Definition.
Jul 30, 2010 | Cameras
Video playback stutters is choppy when the video plays it stops and stutters on a frame. it will play for a few seconds then stutter.
I had a problem similar to this and eventually traced it to the wrong mode setting on the DVD drive's transfer mode.
To check the setting, open Device Manager and then double click on the IDE controllers item. Double click on IDE channel (if there's more than one you'll need to check each one) and then select the Advanced Settings tab. On this tab should be up to two devices and each should show under "Current Transfer Mode" soemthing including the word "DMA".
If any device shows "PIO", then this is probably the problem.
If you Google "PIO versus DMA", one of the top results has a really good article on why this happens and how to force Windows to revert to DMA.
Sep 23, 2009 | Acer Aspire 3000 Notebook
Flip Video Ultra HD MP-4 files playing VERY choppy on my PC
Daniel is a little mistaken with his solution. The resolution of the video is much higher than the little video screen. Stuttering play back has nothing to do with resolution but FPS or Frames Per Second.
Since the video on the little screen is smooth the video should be smooth on your computer as well, just blurry if the resolution is low. However, I am having the same problem with mine and the picture is sharp on my 1080p laptop screen but only appears to stutter instead of playing smoothly.
The camera has dedicated hardware playing it back. This is also the same hardware that is encoding it while recording. My guess would be that the hardware encoding is using a faulty codec that is not playing back well.
Aug 02, 2009 | Thomson Lyra PDP2860 Digital Media Player
DVD picture jumps -- doesn't track
the lens is bad buy a lens cleaner.
Jan 10, 2009 | GoVideo Go Video DVD/VCR Combo
Playback choppy
Camera needs Tape Path adjustment and qualified camera tech person can do the job.
Nov 06, 2008 | Sony Handycam DCR-TRV265E Digital...
Choppy sound and picture when I play DVD
get the divx codec http://www.divx.com/ try adjusting the advanced play back settings in media player my laptop does the same thing sometimes, a few reboots and it is ok again...
Apr 01, 2007 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Televison & Video Logo
193 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
