Gravograph TC2 Instruction manual - Office Equipment & Supplies
How to set a TC2-PROUK TIMER
you can read that in the owners manual. use google to find.
Jan 05, 2017 | Hardware & Accessories
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Sharp mx 2700n tc2 belt day
The second transfer belt is the rubber belt assembly which is inside the right door. The maintenance alert "TK2" indicates that the belt has gone past its' useful life and needs replacement or rebuilding, there is a rebuild kit available.
May 28, 2014 | Sharp MX-2700N Color Copier
Tk2 error
TK2 is for the secondary transfer unit located on the side door. The code will come on after a certain number of total prints, depending on the model. Enter service mode by pressing # * C *, enter number 24 and press the copy button, then enter number 4 and press copy. Highlight everything that says TC2 and press execute on the touch screen. CA will reboot.
Sep 07, 2012 | Sharp Office Equipment & Supplies
How do i get rid of the tk2 code
Jul 15, 2012 | Sharp Office Equipment & Supplies
Need to know how to work a digatil thermostat tc2-prouk
You may download a copy of the manual here.
May 14, 2012 | Cameras
User guide for TC2-PROUK
My hot water heater timer must be obsolete... It is paragon model TC2 series A883-20. It looks as though the trippers X2772 would work. Can you advise?
Paragon is no longer making timers and parts, except defrost timers.
I've seen X2772 trippers selling for $50-60
Can I suggest a replacement water heater timer:
Link below shows variety of water heater timers (including Paragon products, Intermatic, Tork, GE, Sylvania, Woods). Page has wiring diagrams and manuals.
http://waterheatertimer.org/Boxtype.html
Look at label on side of tank to see if heater is 120V or 240V
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 18, 2011 | Hardware & Accessories
Dear Sir! just wanted to know about the TC2 on deep now, today when I am driving my Hummer H2 on deep snow and my passenger right wheel spinning, then I stop my truck and put on neutral and switch from 4Hi...
on your hummer ,as on other 4x4 if in 4 wheel you must have slippage on the tires or you will snap the drive shafts or u joints.the wheels on a turn will turn at diff speeds thats why in 4 wheel it feels like you are crawling over your own fender.its ok if on packed snow or rain but if you have good grip tires it might do it in the rain.never have in 4 wheel lock on dry pavement.
Jan 02, 2011 | 2003 Hummer H2
How to program chamberlain tricode tc2 to my garage door
I HAVE PREWIRED WIRES AND I'M TRYING TO CONECT MY THE WIRES TO MY GARAGE DOOR OPENER. THE PREWIRED WIRES COLORS ARE AS FOLLOWS: BROWN, GREEN, ORANGE, GREEN AND WHITE, BLUE AND WHITE, ORANGE AND WHITE, AND BROWN AND WHITE. WHICH TWO DO I CONNECT TO THE WHITE/RED AND WHICH ONE TO THE SOLID WHITE WIRE?
Feb 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
122 people viewed this question
k24674
