Question about Senco PC2001 2 HP 4 Gallon Electric Hand Carry Air Compressor
Compressor runs until overload release valve opens (pressure at 130 psi) and then air escapes until pressure lowers to 100 psi..Then motor begins to restart, but will not , due to 100 psi and kicks breaker if allowed to stay On... Adjustment nuts do not make any difference.... Motor will restart fine when pressure is below 80 psi.. Thanks for any suggestions.. Len
    Sergeant:
  • 223 Answers
There is a check valve between the compressor and tank, and there is also an 'unloader valve' which blows the pressure off the compressor so that it starts under little load. I think your check valve is stuck open and the unloader valve is blowing tank pressure off.. and when the compressor tries to start it's starting against the pressure in the tank.
So check/replace/thaw the check valve and you'll be good to go. It's generally at the tank where the line from the compressor head goes into the tank, it'll be between the two somewhere.
lp
Posted on Jan 02, 2011
Makita MAC5200.Brand new.Just broke-in. Pressure goes to 140 PSI and stops.Tries restart at 110 PSI.Motor"Humms"only.Will not restart until pressure below 20PSI.
http://www.toolpartsdirect.com/makita-mac5200-3-0-hp-air-compressor.html
There is a part called an unloader. It reduces the pressure on the compressor when the unit stops at the desired pressure. The actual unloader may be part of number 50 in this diagram.
Dec 18, 2016 | Makita Air Tools & Compressors
How to reset the compressor
  1. Remove the screws from the plastic shroud on top of the compressor near the air outlet valve. Use a screwdriver to remove the screws. Lift the shroud from the compressor to reveal the upper and lower pressure limiter adjustment screws. The screw closest to you is the lower, the one farthest away is the upper.
  2. Turn the compressor on and allow it to charge. Make a note of the pressure on the pressure gauge when the compressor turns off. Pull the air release valve to release pressure from the tank. Look for a metal and plastic valve near the air outlet with a metal pull ring through it. Watch the pressure gauge and make a note of the point at which the compressor turns back on.
  3. Consult the tool manual or tool manufacturer's website for the tool you use most often. Look for the optimum pressure range. You may also find this on a printed label on the tool itself. It should indicate the best pressure for operating the tool, for example, "Works best @ 60-120 psi." Psi, which stands for pounds per square inch, is the same measurement you wrote down from the pressure gauge.
  4. Adjust the lower limiter control screw by turning it clockwise to increase the pressure, or counterclockwise to decrease it. Adjust the upper limiter control screw in the same way. Recharge the compressor, noting when it kicks off. Release pressure and note when it kicks on. Adjust the screws as needed until the compressor consistently maintains optimum pressure.
  5. Replace the shroud on the compressor. Replace the shroud screws and tighten them with a screwdriver.
Jul 15, 2015 | Air Tools & Compressors
My D55141 heavy duty 2gal (7.6L) 150 psi max builds pressure up to around 150 releases pop off valve then keeps running, what causes this problem?
The pressure switch is either out of adjustment or has failed. The compressor should shut off at a much lower pressure than the safety valve (~100 psi)
Nov 20, 2014 | Air Tools & Compressors
I have a C2006 Type 4 Porter Cable pancake compressor which will build pressure all the way up to 150psi then cut off as it should but there will be a loud hissing and pressure drop until the cut on...
first you have a reciprocating pump and the hissing you ear probably comes from the unloading valve on the pressure switch(it will look like a bike tire valve)if there is air coming out the valve when the compressor is off it probably means you have a bad check valve.This valve is use to unload the pressure inside the pump for an easy start .a motor always drive more amps on start up if you cant unload this pressure you will trip the overload(you probably have a reset button on your motor)check the specs on your pressure relief valve ,its a small pump maybe its just adjusted to high.in this case your pressure relief valve will open .If the pressure is fine and there is air coming out the relief valve then you have to replace it!to adjust your pressure turn the screw on your pressure switch clockwise to increase and counterclockwise to decrease .usually you have a 30 psi between cut-in and cut-off called the pressure differential.It can be adjusted on some pressure switch.be sure you put some teflon tape on the treads if you replace something to avoid air leaks.hopes this help!
Jan 23, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My regulator broke and I just replaced it. Now the compressor doesn't act like it will automatically shut off when it reaches pressure (130 psi max). Last night it pressured up to right at 130 psi and...
Hi, my name is John. Welcome to FixYa. Look on the pressure switch and see what the max. is. I have some notes here I will have to locate them and I will post them here if you still having problems, but it sounds like you need to replace the pressure switch. Thanks for choosing FixYa...John
Nov 20, 2010 | Craftsman 33 gal Air Compressor 6 hp...
I have an Ingersoll Rand T30 10 HP compressor that runs OK and will bulid up 150 psi without any problems. But when the pressure drops enough to kick the pressure switch, the motor won't start. just tries...
When the compressor comes up to pressure and kicks off, you should normally hear a gasp of air escaping. That gasp is the release of pressure from the compressor itself - not the tank, and it is supposed to get released so that the compressor can restart without being preloaded with compressed air. My guess is that the gasp is not happening. It is probably some debris or a gummy mechanism. The mechanism is supposed to be triggered by the same mechanism that shuts off the motor.
Aug 30, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Motor "bogs down" at roughly 120 psi...almost stops
You suspect this unit as being a two stage because of the unusually high cut off pressure. It is a single stage and the motor really has a difficult task and is being pushed to the limits. to reach this pressure. We usually reset the pressure to lower setting ~~ say around 140. Your pump probably has a leaking intank check valve (brass fitting at tank) or leaking valve plate in pump. Simple tests : with pressure in tank unplug compressor from outlet and listens for air leak around pressure switch. As you unplug the running compressor from outlet you should hear air leaking from pressure switch for just a moment as air is let out of airline from pump to tank. If air leaks out till zero pressure then change the valve. If tank holds pressure then valve probably ok. Next test, with no air in tank and air filter removed, plug in compressor and feel intake port for strong suction. If the valve plate is bad, suction will decrease as pressure neers the 120 mark till the point of feeling that air is actually blowing out of intake. With good valve plate there will be strong suction untill unit reaches set pressure. If valve plate is bad also change the cylinder and piston ring. Good luck with your repair.
Jul 28, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Senco PC2001 2 HP 4 Gallon Electric Hand Carry Air Compressor Logo
285 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
Mike
rickb63
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
