Question about GE WBVH6240F Front Load Washer
I can not find those 3 screws at the bottom. Are you talking about the ones above the panel??? I very much would appreciate help. Thank you very much.
    Top Expert:
  • GE Master
  • 9,472 Answers
Under the bottom panel. There are 3 or possibly 2, but look under the panel on the bottom.
Posted on Jan 02, 2011
Testimonial: "Thank you very much. It wasn't easy since I don't have it on a stand, but I finally did it. Thanks again and Happy New Year."
  • Richard Roth
    Richard Roth Jan 02, 2011
    Sorry, I posted to the wrong post.
  • Richard Roth
    Please disregard
Does not heat food
If the inside light, cooling fan, and turntable all come on when you press "Start" to cook, but it does not heat, then you have a defective high voltage section part (HV fuse, magnetron, etc.)
If the above 3 components do not all come on when you try to cook, then it\'s probably just a bad bottom door switch or mount.
My help file on door switches is here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel which is
very helpful when troubleshooting, testing, and locating
components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt
we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
This additional disassembly information may apply:
Be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they\'re removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
(There are three L-shaped clips that fit into a slot to hold bottom of the vent)
Then remove one screw (which holds the control panel in place) near the top of the control panel.
Once that screw is removed the panel tilts out so you can disconnect the wires and then slip it out.
Be sure to mark and/or photograph your wires so that each one gets back exactly where it was after the repair.
Reassembly is accomplished by sliding the L-shaped keepers in place, then sliding the vent grill to the right and pushing it into place.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven
here.
We\'re
happy
to help you with free advice and we\'d appreciate your thoughtful rating
of our answer.
Nov 27, 2012 | GE JVM1850 1000 Watts Microwave Oven
I am in need of a repair manual for a Toshiba Satellite L455-S5975 laptop in order to replace the LCD screen. I have searched everywhere, but no luck. Does anyone have a source? Thank you.
Not sure if you will find one... Process on toshibas is:
Pop top cover (sometimes also secured with a few screws on side or bottom of laptop) near monitor base above keyboard to access LCD cable and mount screws
Unplug cable and remove monitor mounting screws (Under plate, on back where cables plugin, and sometimes on bottom)
Take monitor (on flat surface) and remove screw covers with needle so you can put them back on later.
Remove all screws
Use plastic credit card and run around outside lip of screen case until removed
Remove LCD mounting screws
Remove LCD and inverter
Remove LCD brackets and inverter from panel
Replace panel and start working backwords.
Mar 31, 2011 | Toshiba SATELLITE L455-SP5016M LAPTOP LCD...
Is there a 'how to upgrade memory acer AOD255E-13405' download somewhere?
If you are talking about increasing the RAM, there usually a little panel on the underside of the laptop accessed by two screws, remove these and replace the chip. Make sure the laptop is off and batter out.
Mar 01, 2011 | Acer Computers & Internet
F02l Problem that everyone else is having/
If this is in reference to the "F21" error code on a Kenmore Elite front loader, the bottom panel is directly below the door. It comes off by removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off.
NOTE: You may have to prop the two front feet of the washer up for better access (a 2 x 4 works well for this).
"F21" is a Long Drain error code, which usually means the drain pump reservoir is clogged with debris, the drain lines are obstructed, or the drain is not working. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If this is not what you are talking about, or if you have questions about this repair, please let me know. I hope this helps you.
Jul 13, 2009 | Kenmore Elite 45986 Front Load Washer
Acceptable distance from cook top surface to microwave?
Sorry but your subject line got cut off. I'll assume you're talking about the distance from the cooktop to the top of the microwave (bottom of the cabinet to which it's mounted).
Here's how the installation instructions spec it:
  • "Make sure the bottom edge of the cabinet that will be above the microwave oven is at least 66" from the floor and 30" from the cooking surface."
So it's measured from the cooktop to the top of the microwave, not the bottom edge.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
You can also download your owner's manual form the link I posted above.
Jun 25, 2009 | Hotpoint RVM1425 Microwave Oven
Replacing driver's side mirror on a 1994 Chevy Lumina sedan
There are screws that hold the door panel on. They are typically located behind the small round plastic covers. If you look at the bottom of the door handle, you will see them. Also on the door lever, there might be a screw. After removing all of the screws, take a flat head screw driver, and gently pry up the panel. There are plastic clips that hold the panel securely to the door. Doing this will pop them out one at a time. Once the door panel is loose, lift it up, and it should come right out. Be sure to disconnect any wiring harness connectors before fully removing.
Mar 24, 2009 | 1991 Chevrolet Lumina
Removal internal front door panel
where the window controls are is where the screws are that hold the door pull,run fingers along under the bottom of door and look for any screws in the panel in this area,remove the window winder control panel by lifting it out,the door panel comes off by pulling it as its held on with plastic push on clips
Dec 31, 2008 | 2001 Jaguar S-Type
Trying to remove 2000 Yukon rear door panel. removed screw on very bottom and one in middle of door. are there more than two screws holding it under the arm rest? I tried prying but it seems very tight...
There are three if we are talking about the same thing.  One at the bottom under the side bin.  One behind the rubber handle above the door latch (this is a long screw).  One behind the window switches. Pry up on the inside seem (long edge), it should come up and then out. The screw is behind it.
Nov 30, 2008 | 2001 GMC Yukon
Olevia 227V LCD
I just repaired a 26" in which the stand came off after I took the primary panel off in the middle of the back then the screws were visible that Olevia is talking about. You might have a different style but it does come off.
Feb 12, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Removing bottom stand Flat Panel LCD Magnavox 32MF605W 32
There are 4 shiny screws at the back of TV just above the stand neck. Unscrew those 4 scrws and then lift the TV up, stand will come out.
Nov 06, 2007 | Televison & Video
GE WBVH6240F Front Load Washer Logo
91 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
