Question about Acer Aspire 6930-6771 Laptop
My laptop shutdown after evry 15 mins... it also get heated
  • Jeffrey Groves
    Jeffrey Groves Jan 02, 2011
    Are you setting it on the bed or other soft surface while using it? That will cause it to overheat.
  • 597 Answers
Try to remove the battery and install it back in, and make sure the vent is not blocked, make sure also that the fan is not blocked, and be sure to have all the hardware components seated properly on the mother board.
If the problem persists, then you will have to rerun the operating system of your laptop.
That way your computer will work properly without shutting down.
Take care and good luck
Posted on Jan 02, 2011
Hello, I have Toshiba Satellite M200 window Vista, I have a new problem after working for 10-15 mins my laptop is getting hang nothing visible on screen just blurred screen , when i switch off and start...
Your Toshiba could be overheating.
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jul 06, 2011 | Computers & Internet
EVRY 5 MINUTE MY ASUS OFTEN TO SHUT DOWN IT SELF WHY?
you have some sort of over heating problem. Most asus motherboards have a built in fail safe to shutdown before component failure happens.
Sep 13, 2010 | ASUS P4S8X Motherboard
Laptop heats and shutdown
May be there is dust in your laptop. Use the laptop with some wooden flat surface instead of pillow, the laptop should heat less frequently
May 15, 2010 | Lenovo 3000 Y410 Notebook
You should not use a laptop on a soft surface such as a duvet or bed covering. The device needs to have free air intake and outlet to cool the processor. If you block the intake, which is probably under the machine, it will overheat and shut down.
If you want to use it in bed put it on a hard surface such as a large book, so that the air intake cannot be blocked.
Mar 26, 2010 | Lenovo 3000 Y410 Notebook
Everytime i turn it on,it will authomatically shutdown.
See if this helps
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Dec 29, 2009 | Dell Inspiron 6000 Notebook
Windows narrator
you have to uncheck do not show tick on narrator.
Jul 19, 2009 | Sony A-1273-689-A - VAIO VGN-FZ Series...
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
Sudden shutdown / will not power up
try check your BIOS.Upon turning ON your laptop, press down the DEL button of your keyboard then check settings of your power.it maybe activated the standby mode by certain time.
Jan 17, 2008 | HP Pavilion ze2000 Notebook
Acer Aspire 6930-6771 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
