Question about Lexmark X4975 Wireless Color Multifunction All-In-One Inkjet Printer
I've been printing on my Lexmark X4975 wireless printer for 2 weeks. I tried to print a document last night and it never printed. The document shows up in the printer que and displays "printing" in the status column but has never printed. The wifi indicator on the front of the printer is green.
  • richardbrock Jan 04, 2011
    Thanks printing working fine now.
  • 10,865 Answers
Hello Richard..... I had the exact same problem last week. After an hour of frustration I inserted the printer disk [the driver] and when the menu popped up I removed all lexmark info from my computer. Then I reinserted the disk and downloaded the same information once again. It works like a charm now. Joe
Thanks for choosing Fixya!
Posted on Jan 02, 2011
Lexmarx X4975 disable complete-a-print
The Lexmark X4975 Professional is a multifunction thermal inkjet printer that not only prints documents and photos, but also makes two-sided printouts, scans and copies materials and accepts line-connected or wireless device print requests. Three color ink cartridges--cyan, magenta and yellow--and a single black cartridge rest inside an ink cartridge carrier. Printer cartridge replacement is not difficult. Each cartridge is secured in place with a cartridge carrier lid that opens with the simple press of a lever.
  • Turn on the Lexmark X4975 printer. Lift up the entire scanner unit to rest in an open, angled position that reveals the interior of the printer.
  • 2
    Press down on the lever in front of the printer cartridge that you need to replace to open the cartridge carrier lid.
    • 3 Pull the old cartridge from its slot in the carrier.
    • 4
      Grasp the tab attached to the tape covering the electrical contacts and ink nozzles on the back and bottom of the replacement printer cartridge. Pull the tape away from the cartridge carefully without touching the contacts or nozzles.
    • 5
      Insert the cartridge into the empty slot--the electrical contacts facing the back of the slot inserted before the front of the cartridge.
    • 6
      Flip the cartridge carrier lid over the top of the cartridge and then push down on the top of the lid until you feel the lever lock the lid in place.
    • 7
      Repeat the replacement process with the other printer cartridge if necessary. Lower the scanner back into position when finished.
      Increase Engine Horsepower.
Jun 02, 2012 | Lexmark X4975 3-in-1 Wireless Inkjet...
Lexmark interact S605 has document blocking any further printing and even when I have unblocked previously the next document still blocks
If you're having problem with print jobs getting stuck in the print queue, it could be due to your computer's print spooler service not running. Try the steps below to fix the problem:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 09, 2012 | Lexmark Interact S605 All-in-One Color...
Lexmark wireless printer 1400 series prints blank pages
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark Z1400 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Jan 22, 2012 | Lexmark Z1420 Printer
I down loaded firmware Lexmark 405 last night- now the paper shoots through the printer without any print on it
Try to clean the printhead nozzles on your printer. From the printer operator panel, press the Setup button > Maintenance > Deep Clean Printhead. Your printer will then print a test page forcing ink through the printhead nozzles and clean them.
You may also try to re-insert the cartridges in the printer.
Sep 02, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark x4975 printer not communicating with computer
This article from the Lexmark website on No Communications Error When Trying to Print or Scan might help resolve the problem. Or simply unplugging and replugging your printer into your computer and into the power source can help fix minor communication issues.
Feb 21, 2011 | Lexmark X4975 Wireless Color Multifunction...
When I send a document to print, the document seems to get 'stuck' and won't print. The status bar stays at about 50%. Sometimes it prints, sometimes it won't.
It could be the print spooler of your computer that has gotten disabled somehow. Try to refresh the print spooler on your computer by following the steps in this article in the Lexmark website on How to Restart or Reset the Print Spooler in Windows. Once the spooler has started, make sure there are no print jobs stuck in the print queue before sending out a new print job.
I have brought a lexmark x4975 printer with no manual or disk.... and have not got a clue how to set up wireless printing... please help
Wireless printing happens in conjunction with your wireless router. You need the access information for that. Then go to Lexmark website and download and install the software for that printer, and follow the directions exactly. Each computer will need software installed in order to connect.
Sep 26, 2010 | Lexmark X4975 Wireless Color Multifunction...
Cannot print from network. Computer cannot cannot communicate with the printer although the printer is registered on the network
it must be problem with security settings so give security permission to print and also check if something is blocking like Firewall and turn off the WS Firewall
Apr 23, 2010 | Lexmark X4975 Wireless Color Multifunction...
Printing errors
Try printing one page at a time and see what happens. Repost!!
Jun 15, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmark X4975 Wireless Color Multifunction All-In-One Inkjet Printer Logo
107 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
