Question about Miller Welding Tools
My Syncrowave 250 has no argon flow . Everything else works.
    Problem Solver:
  • 9 Answers
Remove the gas flow solenoid valve, bench test or have it tested and or replace. Follow the gas line to machine .This should be your gas solenoid If solenoid works fine, there must be a wire broken going it to itbut most likely tthe solenoid is bad.
Posted on Jan 05, 2011
Can't set up syncrowave 351 to tig weld aluminum. I can not seem to get the settings right to melt the aluminum. It just leaves a bif spot on the aluminum plate.The plate is about 1/4" thick and...
Set the "arc balance" control between 40-50, also. You need to be up around 200-220 amps too. Make sure you're using 3/32 tungsten (green, red) and running about 25-30 cfh on your argon. Ball that end on the tungsten.
Oct 08, 2011 | Miller Electric Manufacturing Electric...
Gas keeps running after you let off the foot pedal on synchrowave 250
Hi:
The normal set up on the 250 syncrowave will allow you to control your pre and post flow of gas. If the post flow is set up to more than 2 seconds that's the problem. If it is set on zero, then you have a leaky solenoid valve. Check your owners manual for troubleshooting anf repair.
Aug 02, 2011 | Miller Electric Manufacturing Electric...
What is the best settings for alum.
to weald alluminum you have to have argon gas head and gas. The setting depends on the thickness of the alluminum.
Feb 25, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Syncrowave 250 dx aluminum set up
You can go to millerwelds.com and download the manual for this machine..it should help you
Dec 13, 2009 | Miller Electric Manufacturing Electric...
Miller syncrowave 250 tigrunner with gas flow
Your problem is in one of two areas. The controller board inside the unit or a bad trigger on your gun.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 25, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
No power on eletrode Miller syncrowave 350
check your input power is the same as your old place where it worked.
Mar 17, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Tig my pudle melts into gray not shinny
Ensure you have the correct angle when using the torch = 22-24 degrees from vert: this will provide good gas coverage. setting should be 15 - 20 ltrs using a "flow meter".clean the material thoroghly then weld , dont clean then leave for a long time.
Argon gas sometimes can be contaminated and cause heavy soot on the weld bead,
TIG electrode should be Zirconiated with a rounded end not pointed.
Use forehand ,method
Feb 02, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Aug 27, 2008 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Welding Tools Logo
275 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
