Question about Sport & Outdoor - Others
I have a proform xp 110 elliptical. The console lights up and all the controls work, but we are unable to change the resistance. You can change the resistance on the console, but it has no effect on the actual resistance.
maxtreadmill
  • 832 Answers
SOURCE: Change batteries in consol of elliptical, but
their maybe a loose connection between the upper display and function controls I would pull apart the upper display and check the connectors between the two boards
Posted on Mar 01, 2010
maxtreadmill
  • 832 Answers
SOURCE: pedals/resistance locked
Was this at a retail store you should exchage it.
If not then you will have to take the side off need to inspect all mechanical attached to the rails. It will be apparent to see the flywheel their eddy current transformer on top of unit or the flywheel itself is one package their should be are wire comming out of trace it back to the circuit unplug the connectors the resistance should be gone now test the mechanical function of unit to see if the pedal are free from any binding then reverse connectors and see if you can adjust the resistance if not the board is defective.
Posted on Mar 03, 2010
SOURCE: I have a Tunturi C6,
Power issues with
Tunturi C6 fit into two categories: the power does not turn on or the power shuts off when using the Tunturi C6. If the power will not turn on, make sure that the Tunturi C6 is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the Tunturi C6 . Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the
Tunturi C6 will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the
Tunturi C6.
If the
Tunturi C6 shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Take care.
Posted on Aug 26, 2010
ercupa190
  • 12223 Answers
SOURCE: Proform elliptical - totally dead. help?
1) must shure if the electrical power from your house is o.k reset the c.breaker or replace blown fuse, test with lamp desk.
2)test the power cord if are open, or break, or burn
3)clean the contacts batteries with alcohol 100% from oxide, dust, corrosion.
4) Resolder any wires and connectors clean and tight very well.
5) tights the bolts from your machine attached.
6)Verify now.
Posted on Jun 21, 2012
ercupa190
  • 12223 Answers
SOURCE: Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
Posted on Aug 30, 2012
What would cause the resistance to stop working on the console of my Proform 390 E elliptical?
How to Replace an Elliptical Resistance Motor
of course see if the cables is good, and test the batteries
or connector before and cleaned with electronic contacts cleaner-
test the terminal at motor for 9VDC APROX if there are the motor is faulty, use the DMM.
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 15, 2018 | Proform Exercise & Fitness
I have a Proform Hybrid elyptical/incumbent bike and the resistance levels no longer work .How do I repair this?
Hi There ,
There might be a problem with the resistance motor.
Ring Icon Fitness, they are the distributor for this brand world wide.
Sep 10, 2014 | Proform Hybrid Trainer Elliptical And...
My 390 E is locked up and I can't move the pedals. I checked the belt, it's still on and it's tight.
follow this steps and fix it. God bless you
Electronics Problem You control the tension of the pedals using the buttons on the console. When you assemble the A.C.T. elliptical, you have to thread a group of wires from the console through the upright down to the electronics board. These wires communicate the resistance settings to the electronics board. If the wires twist, disconnect or break, the resistance will not work. You will need to reconnect or replace the wires.
Read more: http://www.livestrong.com/article/406522-tension-problems-with-the-nordictrack-a-c-t-elliptical/#ixzz2Z4kLeLBm
Jul 14, 2013 | Proform PFTL79807 - 850 W/ Gamefit...
Resistance not adjusting
Reading on HSN website, it is b/c this product is junk. Dozens and dozens of reviews stating the resistance is stuck and wont' change.
http://www.hsn.com/products/proform-smart-strider-spacesaver-elliptical/6647352?query=6647352&isSuggested=True
Jan 20, 2013 | Proform Smart Strider SpaceSaver...
God bless you
Aug 27, 2012 | Proform Nordic Track Elliptical Resistance...
Reebok RL 1500 elliptical lost all resistance
I had the same exact problem, and I mean the EXACT same problem. I also changed out the battery with no change. I contacted the generator company thinking it might be that, but they told me it could be the control board. I ordered a control board, changed it out, and now it works like new.
To sum up: Get a new control board.
Jun 19, 2012 | Reebok RL1500 Elliptical
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
I have a proform 390E, and it has a resistance problem, I just checked all the wires and they are connected properly, what should I do now?
Have a 390E elliptical. riding on resistance 4 and then it shut off and went back to resistance 1. now it will not accept any resistance, if you punch in 2 or 3 it registers and then drops back to 1. battery problem? help
Apr 29, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
My Proform elliptical is not working
clarification: when I get on the stepper there is not resistance. I'll get to a point when my feet will bascially fall right around....like something is loose or broken
Oct 17, 2009 | Proform XP 590S TREADMILL Drive Motor
Sport & Outdoor - Others Logo
49 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
