Question about Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse SK-32H540S 32 in. LCD TV It went off by itself and now will not came back on. The power light flashing I did unplug it for an hour and that did not help.
  • 1,557 Answers
I have been a tech for 26 yrs now i have seen so many postings on here about bulging caps and so on but there is only 1 thing to do our workshop has 18000 dollars in test equipment alone there is a great reason for this the amount of vereables that can go wrong with nano electronics there is no easy fix to this problem it needs to be seen by a certified electronics tech this is your best chance of having this tv fixed correctly im not putting down other techs on this site but some things we can fix by computer network some we cant imagine even if this tv was in my workshop right now it would take us over an hour just to find and fix the cause
i hope this helps you sir/mam
sonic boom electronics australia pty ltd.
managing director
Posted on Jan 02, 2011
Testimonial: "Thanks That was what I was thinking I would have to do anyways, but never hurts to ask."
  • sonic boom electronics
    sonic boom electronics Jan 02, 2011
    your most welcome and you would be surprised how many things we can fix over the net so yesit never hurts best of luck with the repair.
    President:
  • 662 Answers
Users Manual (useless):
http://dl.owneriq.net/3/31e26663-7b4e-44c4-0107-bcc6f58dc83e.pdf
www.legacywd.com/pdf/206_User_Manual.pdf
Westinghouse home page (useless - they fail to provide support or even manuals for older models):
www.westinghousedigital.com/support
Could be a lot of things, but most likely is LCD Inverter Board, which lights
the LCD display with white light.
Another possibility is loss of 24VDC switched power from power supply.
Possible sources of replacement LCD inverter boards:
www.shopjimmy.com, www.ebay.com, search for refurbished LCD inverter board.
Westinghouse 32H540S Remote Program
You have this backwards. The codes are in the remote. If you are using a Westinghouse remote, there should be no programming necessary. If you are using a universal remote, you can use the code search function to find a code that will control your TV.
Dec 03, 2013 | Westinghouse SK-32H540S 32 in. LCD TV
Tv powers on for a second then powers back off
hi, it sieams like, the power suplly is the cause.
for the fail of the voltag.
Feb 07, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
As it has become clear, there is a problem with Westinghouse SK-32H540S , burning or chemical smell. Is this an easy repair or total wash ?
What is the problems of the response of the tv?Tv power LED light indication flashes or totally dead?Or something else problems?If it is the tv power problems.The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 20, 2010 | Westinghouse 32" Flat Panel LCD HDTV
My Westinghouse SK-32H540S TV comes on for about 5-10 seconds, then the picture goes off. The sound continues.
You need to replaced your Inverter Board, If you can do the job, get the Board Part number and order it from Westinghouse. If not call a Professional TV Technician. At least you have an idea what's the trouble with your set. Hope this Tip will help you.Thanks
Aug 12, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse LCD TV SK-32H540S, 1 year old. When I turn it on, the screen works for about 5 seconds, then goes dark; power is on - sound still works but no picture
1 swollen Capacitors / Replace
2 blown Diodes on inverter board / on some # 508 or 908
3 bad transistors in inverter bad will appear overheated powdery coat
4 replace inverter if you cannot locate problem on it
there is a safety built into the high power back light supply and that is if too much current is drawn or light is shorted it will not burn up
or hazard high volt shock to user.
capacitors and diodes driven with power transistors
look for darkened spots on the board to identify hot transistors
puffy tops and leaky bottoms of capacitors
when you turn it on does the bottom or top of the screen show image a Milli second before the other it should be evenly the lag
is the one requiring more amperage
Aug 07, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse sk-32h540s TV, VGA input, image can't center.
Hello, two things, one try using the TV with the native resolution of 1366 X 768, and secondly try updating your video card. If you are not having this issue with the TV on the other inputs than most likely it is a settings issue with the laptop. Please rate this comment if it was helpful.
Apr 06, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Won't turn on. Westinghouse SK-32H540S 32 LCD
Try leaving the TV unplugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. Or, it maybe something simple like a blown fuse inside the TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If the fuse doesn't fix it and If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem with the power supply and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 04, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse SK-32H540S 32 in. LCD TV Logo
602 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
