Question about Grundfos JPS4 1 HP Pressure Booster Pump
My Grundfos JPS4-A is not turning on. There is power to the pressure control and it is making contact showing that the sensor is working. I took off the cover to the top of the pump where it houses the incoming electric from the pressure control and there is electricity to there, but pump is not running or even trying. It does not smell burnt. Is there a reset button? I can't find one. Any other sugestions?
3 Suggested Answers
  • 5 Answers
SOURCE: will not keep pressure
you need to get a linear one way check valve and install it on the outlet side of the pump as close to the pump as convienant. It would be a good idea to put a traditional one way flapper valve on the inlet side as well. It worked well for me.
Posted on May 14, 2009
  • 3 Answers
SOURCE: My Grundfos JPS4 1 HP Pressure Booster Pump keeps coming on for a
Definately sounds like a leak in the pipes from the pressure side of the pump onwards, even the smallest leak will cause it to turn on to regain adequate pressure.
Posted on Jul 09, 2009
Water leaking from from pipe under bottom control
normally they have a) gasket + b) O-ring open and replace it ,remember use teflon for to avoid and help leak too.
God bless you
Nov 12, 2013 | Grundfos JPS4 1 HP Pressure Booster Pump
Grundfos pump
It sounds like you have a bad pressure switch. I would also check the pre-charge pressure in the expansion tank. This needs to be 2lbs less then the "cut-in" pressure of the switch IE: 30-50 switch 28lbs air in pressure tank.
RJH2O
May 11, 2013 | Grundfos JPS4 1 HP Pressure Booster Pump
Grundfos water pump is humming with no turning, if I take pump cover off and turn the shaft it starts?
Sounds like it could be a blown capacitor in the motor. Disconnect from the power supply and remove the capacitor - it is usually situated undet the terminal box cover- examine it for leakage or distortion and replace it if necessary.
Jan 04, 2011 | Grundfos JPS4 1 HP Pressure Booster Pump
I have a grundfos mq 35 pump to boost pressure in my hot and cold system. due to loss of water recently pump ran dry and shut down. when water returned the system was restarted and pump reset. we now get...
There was possibly some damage done to the pump while it was operating dry and it in now not able to deliver the required flow of water. Pumps wear very quickly when allowed to run dry, even for a short time.
Jan 02, 2011 | Grundfos JPS4 1 HP Pressure Booster Pump
Grundfos Pump Wont Stop Running
Close the outlet valve then turn electrical switch on manual for a few seconds until any air is pushed out then open the valve and return electrical switch to automatic.
Aug 07, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
SOUNDS LIKE YOU HAVE A LEAK DOWNSTREAM PROBABLY UNDERGROUND. THE PUMP HAS NO REASON TO COME ON EXCEPT TO BUILD THE PRESSURE BACK UP. HOPEFULLY YOU HAVE A GAUGE IN THE DISCHARGE LINE YOU CAN WATCH IT DROP AFTER THE SYSTEM SHUTS OFF. HOPE THIS HELPS, JODY
Apr 27, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
Will not keep pressure
Mar 26, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
Grundfos JPS4  1 HP Pressure Booster Pump  Logo
79 people viewed this question
Top Grundfos Plumbing Experts
john h
Andrew Bugbee
Are you a Grundfos Plumbing Expert? Answer questions, earn points and help others
