Question about Miele W4840 Front Load Washer
I have the miele 4840 washer and the door has always been out of alignment for the catch. We usually lift it a little so it closes easier, but thats the way it was from day one. Just wondering how hard it would be to adjust the hinges so the door closes easier. The dryer works fine. We are two adults, and have never ever leaned on the door because you just DONT do that
4 Suggested Answers
SOURCE: Miele WT945 Washer/Dryer
You can get fluff out by opening the small lower left front panel with the yellow plastic lever/opening tool (on the left hand side of the washing powder draw). Make sure you place an empty container under the tap on the opening panel door to collect the condenser water. Water will flow as soon as you turn the big plastic dial (which holds the fluff). Once water stops flowing, completely unwind, take out the fluff dial, clean and retighten dial back. Close lid and you are set to go!
Posted on May 21, 2009
  • 128 Answers
SOURCE: Miele W1926 washer shakes more then usual when spin.
I'd start simply.
They do move over time and if the floor is not even the machine will be out of balance.
If you have not done so check the machine is still level and all feet are solidly on ground.
Try to shake the machine by hand and see if is solid on the ground. There are leveling legs under the unit you can adjust.
Hope this helped. Please rate answer if it does.
Posted on Mar 11, 2010
  • 6277 Answers
SOURCE: Door locked on my Miele
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 31, 2011
Miele dishwasher door leaks through the fan on front of door
That is supposed to be open only during drying. You most likely have a problem with that air vent opening and closing properly.
Feb 01, 2015 | Miele Dishwashers
Why does my new dishwasher not dry dishes completely?undefined
Mieles do not have a drying element - this is a big energy saver. They save heat from washing and use that to dry the dishes. Sometimes they will not be quite bone dry at the end of the cycle, but most will be dry if you open the door for a little while to let air circulate.
If your vent (port on the front) is blocked then the machine will not be able to blow out the damp air, and you will have wet dishes as you describe. If you have leaking from that port, then check my answers on "the Miele problem" which I am pasting below.
You have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is an idiotic problem that Miele should have a permanent fix for. Grrrr.
The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk.muck and slop.
Doggone design sucks on an otherwise nice machine!!
Sep 29, 2014 | Miele Dishwashers
Why is my miele 645 leaking from turbothermic vent
You probably have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a silly and idiotic and useless problem that Miele should have a permanent fix for. Grrrr.
Sep 07, 2014 | Miele Dishwashers
Door vent spitting water
Sounds like you have the Miele Problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service, but it is easy to learn to do it yourself. It can be done at home with no added parts. I think it applies to all Miele dishwashers, at least for a number of model years, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk, muck and slop.
Apr 02, 2014 | Miele 24 in. G692SC Plus SS Free-standing...
Miele g 1874 scvi, finished sound
Is this a high-pitched whine or screech? If so, then you have the Miele Problem.
The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service, but it is easy to learn to do it yourself. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
Feb 16, 2014 | Miele Dishwashers
Miele dishwasher leaks when door opened and end of wash
Do like the others said. This is what I call the Miele Problem!
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
Jan 03, 2014 | Miele 24 in. G665 Built-in Dishwasher
My miele dishwasher makes funny noise from steam fan and leaks steam onto the custom panel
In fact, I just did this today -- doggone design sucks on an otherwise nice machine!!
Sep 12, 2013 | Miele Dishwashers
W310 door catch wont close
need to remove the rubber around the door its a bit of a faf though
Sep 27, 2012 | Miele W310 Front Load Washer
I have a 1997 Jetta and all of a sudden the drivers door will not engage when trying to close the door. The door is not catching. please help. linda
I had the same problem on mine.
Tyr this: Use the interior handle and lift it. Hold it and, with a pencil, you need to lift a little part on the lock system. Once this is lift, the door will engage. Now do not lock your door before closing your door!
Jun 17, 2010 | 1997 Volkswagen Jetta
Miele W4840 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
