Question about Toshiba 43HX70 43" Rear Projection Television
I have sound but no picture>
  • 1 more comment
  • billboyett Jan 02, 2011
    Is it worth fixing or should I replace the TV. There are some good buys out there.
    In your opinion is the TV worth fixing or should I replace it?
    Thanks again for your help.
  • 597 Answers
The t-con board of your television is bad, that is why your television is having sound but no picture.
The t-con board is by the upper middle of the main panel of the television, Have it replaced and your television will be in good condition once again.
Hope this was helpful to you.
Take care and good luck.
Posted on Jan 02, 2011
    Thanks
  • clarke richardson
    clarke richardson Jan 02, 2011
    Yes it is an easy fix and it will cost you less. But if you feel more comfortable getting a new television, then you can get one. But i will advice you get the t-con board fixed instead.
    Sergeant:
    Champion:
  • 342 Answers
The bulb migh be burned but you can check the manufactuer for details on purchasing a new bulb
    There are 3 bulbs and they all look in tact. Someone said something about the t con board.
  • Ryan Nguyen
    Ryan Nguyen Jan 02, 2011
    ahh then the tcon board may be bad or the guns may be bad i would have to see a picture of this
Philips model 52pfl5704d/f7 no picture and no sound
Could be an open internal fuse or power supply failure
Jun 12, 2017 | Philips Televison & Video
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
After trying to plug in headphones (in the headphone socket) I have lost all sound on my Toshiba satallite 2040 (Idid have sounds from built in speakers before hand) can you help
Hi
You have not mentioned which operating system you are using.
You might have changed the defaul audio settings.
Vista/Windows 7: Start > Cxontrol Panel > Sounds & Audio Devices > Hardware & Sound > Manage Audio Devices > highlight the external speakers from the list of devices > Set Default > Apply > OK > Restart computer.
Win XP: Start > Cxontrol Panel > Sounds Speech & Audio Devices > Hardware & Sound > Change the Speaker Settings > Advanced > Speaker Setup - select Internal Stereo Speakers > Apply > OK > Restart computer.
I hope this helps.
Aug 27, 2011 | Toshiba Satellite 2450-401 Notebook
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
How do i turn off the message keypad noise that happens when im typing a text message?
Sounds
• To set volume for media and videos, from the home
screen, touch Menu > Settings > Sound &
display > Media volume.
• To play tones when using the dial pad, from the
home screen, touch Menu > Settings > Sound
& display > Audible touch tones.
• To play sound on a screen selection, from the home
display > Audible selection.
Feb 22, 2011 | Motorola Mobility Defy Cell Phone
Picture bowed & Colors separted
Conversions are out....RCA>>>>>>>>>>>>>check
fuse by the flyback transformer
May 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
What does AA on the display screen mean? THis is on my display scrren, also when i get a call, an automated voice sounds saying"call from____"
I have an SCH-U450 and had the same annoying AA on my nice wallpaper picture.
Although it doesn't appear in the icon library, apparently, it's for Auto Answer. As soon as I turned that off, it went away.
In my phone to to, Menu > Settings & Tools > Call Settings > Answer Options, and make sure Auto w/ Handsfree checkbox is UNchecked (unless, of course, you want it on, in which case, I guess you're stuck with the AA in the middle of your nice wallpaper picture).
As for the audio announcement, mine was set when I got it to yell out the name of the contact for messages and calls. Try Menu > Settings & Tools > Sound Settings > Call Sounds > Call Alert, then choose Ring Only, or others as appropriate.
Feb 27, 2010 | Samsung SCH-U470 Juke Cellular Phone
Scroll function not working on my Dell inspiron
Try This.... May work if touch-pad driver is installed correctly....
Go to control panel ---> choose control panel home ---> click hardware & sound ---> click the 'mouse' word(mouse properties will appear) ---> select dell touchpad ----> click on the touchpad diagram( dell touchpad setting will appear) -----> select scrolling option -----> tick enable on the checkbox ----> then click apply and ok..... [ here, i attached picture aiding you with the step ] ( gud luck )
Jan 27, 2010 | BenQ Joybook 5100U Notebook
Where does the Olympus XD Picture card go in my computer?
you need a Home > Computers & Software > Memory Card Readers > Olympus 200830 xD Picture Card Memory Card Reader > Product Details Buy it from one of these stores: * B&H Photo-Video-Pro Audio Overall Rating: 9.8 $29.95 * Amazon.com $35.49 * Buy.com Overall Rating: 8.7 $34.17 Olympus 200830 xD Picture Card Memory Card Reader Olympus 200830 xD Picture Card Memory Card Reader Price Range: $29 to $49 at 10 store.......sodeep
Jun 09, 2009 | AOpen Olympus 64Mb xD-Picture Card (AX4C...
Sound is now unavailable
Please try to check your audio by right click (mouse) My Computer icon (on the desktop screen) > click Properties > select Hardware tab above > click Device Manager tab > click +Sound, Video & Game Controllers > double click your selected Audio Controller device- wherein you can see if the device status is working properly as well as if the Device Usage is Enabled, if not click Troubleshoot tab.
Or you can also check your Sound / Control device thru Start > Contol Panel > Sounds, Speech & Audio Devices > Sound & Audio Devices - wherein you can adjust the volume & test your sound.
Or you will have to reinstall the sound driver. best regards
May 21, 2009 | Gateway FPD1775W Monitor
Toshiba 43HX70 43" Rear Projection Television Logo
104 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
