Question about Breville BES820 Espresso Machine
After successfully using the machine I tried to make a second coffee. Water continually poured into the tray and the machine sounded very loud (as if it was starting up). I then tried to shut down the machine by pressing the power button but it would NOT switch off!!!! I had to pull the plug to shut it off. After repeated attempts, the same issue occurred. Help, the caffeine is wearing off.
    President:
  • 1,618 Answers
The coffee grind is too fine, or you are tamping too hard, First remove the portafilter and press the brew button if water flows move on if not remove the shower and clean. Now that we have a nice flow of water without the portafilter. Now we will add coffee to the portafilter, and level it out, do not tamp and try to run a coffee, if that works then the Tamp is the problem, if you tamp and still have the problem then the grind is too fine.
Posted on Jan 05, 2011
Have a bunn vps series pour over that won't brew
VPS are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on. Brewer will pre-heat the water (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* You can test the VPR by following the Pre-fill instructions I've listed earlier. If the brewer heats up and does not continuously boil (shorted condition) then try a brew. If it works then your okay. Otherwise the unit will need service for a blown high limit or bad heater element.
* Call your coffee vendor anyway. Many coffee vendors will service your brewer of even replace it as long as you buy coffee from them. Ask around.
Aloha, ukeboy57
May 27, 2017 | Bunn Coffee Makers & Espresso Machines
Giro plus - red light flashes rapidly, tried priming with no success. Anyone have any answers?
Have you tried draining off some back-pressure. That often is what the rapid flash means. Try pushing the hot water button then opening the steam valve. A few seconds after the pump comes on to push water out, the red light should go off. If it takes more than a few seconds, that's probably not the problem. hope this helps.
Sep 27, 2014 | Saeco Odea Giro Plus Coffee Maker
Water overfill
The A10 has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
PS. Check your using the correct size decanter for this brewer. If it's a 10 cup brewer then make sure all the decanters in the office is also 10 cup. Pouring a 12 cup pot into brewer will have 12 cups of coffee come out (over flowing the 10 cup pot.) Note that not all decanters are made the same size. Other brands may be different. Test by filling a pot with water (from faucet) then pouring directly into pot in question. It should match and not under fill nor over fill.
Apr 04, 2014 | Bunn A10 Coffee Maker
Steam comes out from the tray grill
Sound's like you have a crack somewhere in the tray,
You could try locating it and sealing it.
Jan 15, 2014 | Jura Capresso Impressa F7 Espresso Machine
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
I think my bunn-o-matic VPR needs cleaning and I do not have a manual for this machine. Can you advise on how to do this?
To clean the vpr you will need to take the lid off the machine. Be sure to unplug while doing this. First clean the water tray. You can unscrew the nut holding this tray and clean the tray in your sink. Put the tray back in and put the lid back on. Plug coffee maker in. Fill one coffee pot with vinegar and pour it in machine. After the water finishes coming out let the coffee maker sit overnight. Before you start filling the maker with water at least 6 times, be sure to clean the spray head. Make sure the 5 or 6 holes are free and clear of any build up. Then start with fresh water. Fill the coffee pot with fresh clean water and pour into machine. Let it finish and do this at least 6 times. If you can still taste or smell the vinegar repeat until you cant.
Mar 19, 2013 | Bunn Pour-O-Matic VPR
We have this machine that we purchased in Italy in 1995 and it heats (left button) and steams but I can't get the water to pump (right button) through the coffee to go into the cups. Makes a loud clicking...
Obviously you have problem with non return valves at the pump, they are built inn the pump.
  • Remove the filter holder, open the steam valve and command brewing coffee. If water comes from steam valve close it> continue brewing and wait the water from coffee group. After this procedure test it with coffee.
  • If testing with coffee is successful you may work with that pump but always be careful to not leave empty water container.
  • If testing isn't successful you need to change the vibration pump.
Feb 24, 2011 | Elektra (SX) Espresso Machine & Coffee...
The tray (JURA J5) keeps indicating that it needs to be emptied inspite of it being empty. How can i fix this problemo? Thank you.
The connectors at the back have liquid on them use a lint free cloth to remove the liquid and the tray fault will go away. If you want to prevent this make sure that when you pour the water out the tray you pour it out the side not the back and this is how the liquid or debris gets stuck there
Oct 31, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
New to expresso machine - Cuisinart EM100c
This is a very loud machine. Here's the normal operation: You turn it on, and wait a few minutes for it to heat up, at which point the heating light will go off. Then make sure the function knob is turned to coffee, and it will start brewing. At first, it will make a short (loud) sound and then stop for a second. The purpose behind this is that the machine is pre-wetting the coffee, so that steam can more easily shoot through it in a couple of seconds. Then the loud noise will start again and run continuously until you turn the function knob back to the center. So, the sounds you were hearing were normal. There is a delay between when you hear the sounds and the water starts flowing out. If the coffee is pressed down (tamped) too hard, that delay will be longer. Hope this helps. You made a much better choice purchasing this machine rather than the more expensive EM-200, in my opinion.
May 10, 2009 | Cuisinart EM-200 Espresso Machine
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Breville BES820 Espresso Machine Logo
399 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
