Using an LG 42LC50C TV at hotel. Where to hook up. Tried any combination of red and white entries in the back. Headphones are charged and was working when we left home. Any ideas?
SOURCE: LG 32LX1D 32 not turning on
i found the solution.. put the cable back in the tv and let it plug on 1 wik and try totrun it on from time to time.. it works to me...
Posted on Apr 22, 2008
SOURCE: Connections
conect ps3 audio throw optical
Posted on May 20, 2008
TBlessed 1
  • 61 Answers
SOURCE: Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Posted on Dec 01, 2008
  • 25 Answers
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Posted on Apr 02, 2009
  • 3 Answers
SOURCE: TRYING TO HOOK UP HEADPHONES,IS IT CAPABLE.
Hello, IF your tv is capable of using headphones it will have a little jack with a head phone symbol over it or under it most likely. IF not you can buy a home theater system which would hook up to your tv and some of these have an option to hook up headphones or even ipods and usb devices.
the greek
Posted on Jun 06, 2009
I can't get sound through my headphones on my Bravia kdl-52xbr5 tv. First time I have tried to hook up the headphones which are sharper image wireless
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Dec 16, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
DOES LG 37" MODEL # 37LB4DS-UA.AUSLLJM HAVE A HEAD PHONE JACK
On the back of the tv and the cable box should be red, white and yellow rca jack, the white and yellow are sound
Feb 19, 2012 | LG M2280D 22 in. LCD TV
I am attempting to use my sennheiser rs 110 headphones with my lcd-led tv. the componet jacks coming out of the transmitter are red and black. All my componets on the tv are red and white. so when i plug...
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
Mar 10, 2011 | Sennheiser RS 110 Consumer Headphones
I do not have a remote for my model LG 42lc50c and i cannot get to switch from AV2. Is there a way to do this without a remote?
The button that switches from AV2 is the "Input" button, on the lower right side of the TV. But keep in mind, another Audio/Video source needs to be plugged into another input (located on the back of the TV) in order for this to work. The TV has to recognize multiple input sources to switch between them.
Jan 25, 2011 | LG 42LC50C 42 in. LCD TV
I'm trying to hook up a 5-speaker Dolby surround
out of tv, into the combo, out of the combo into the surround amp and this work
Sep 01, 2009 | Televison & Video
XBOX not connecting to LG flatscreen -no visuals only sound
There is a switch on the cable where it plugs into the XBOX that says HDTV/TV please make sure that it is set to HDTV when using component connectors.
May 13, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
When connecting XBOX live to LG flatscreen there is no video only
There should be a switch on the cable that says HDTV/TV if you are using component connections, make sure that the switch is set to HDTV.
May 12, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
TV channels
If cable is hooked through cable box with a coaxial cable, then turn tv to ch 3 or ch 4 as appropriate.
If cable is hooked through any other type of cord (red/green/blue or red/white/yellow) use the AV+ or Source button to change your source to Av1, AV2, HDMI, or however you have the cable box hooked to TV (I am assuming your TV is a Philips).
Feb 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
