Question about Refrigerators
Fridge leaks i have a sears kenmore coldspot fridge. It leaks from the inside and down the back of the fridge. What can i do to fix this
    Scholar:
  • 148 Answers
Dfrost the freezer ,it will take almost a day,put two bowls in frige on top shelf to catch the water thru the vents,once you hear water run into the drain pan which is underneath the fridge on the condensor your done,dry up water in fridge and plug back in,its your drain hose is frozen,after you plug it back in if you get the problem again you have to replace the defrost timer
Posted on Jul 08, 2008
    Genius:
  • 1,122 Answers
Your drain is clogged,you need to get to the drain and use a hanger or shop vac to **** the clog out,let me know-mike
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
Water leak from my Kenmore Coldspot Frig Model 106. 59792990
U have a restriction in drain tube under evaporator coil. So every time it goes into a defrost instead of going down the drain tube it is running over and out the front of fridge
Mar 08, 2013 | Kenmore 53642 / 53644 Side by Side...
My kenmore coldspot refrigerator is warm with water forming inside yet freezer is working
It could either be a fan at the back of the freezer not working or short of gas. Some fridge/freezers control the fridge section with a fan blowing the cold air down the back when required, but all evaporator coils will ice up at the start from continuously running and trying to cool the end of the coil.
May 06, 2011 | Refrigerators
Top freezer leaks water into lower fridge on our sears kenmore #70267990
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 26, 2009 | Kenmore Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Kenmore Coldspot freezer is buzzing loudly
See if pressing on the back panal makes a difference and see if anything is putting pressure on the panel. If its vibration it is trial and error to get it positioned to quiet it down. If it is the bearing replacement is the cure.
Eric
Jul 03, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Warm refrig and freezer
You probably need some refrigerant added. There probably is a leak in the system that caused the lack of refrigerant. Get the leak fixed and add refrigerant before you blow your compressor too. Or get a new fridge.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
199 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
