Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
I have mildew (or some other black crud) under the edges of the glass shelves of my sub-zero 650--I cannot get to these areas because of the metal framing surrounding the glass. One edge of the framing is rubberized and flexible, but not so much so that I can free the glass pane from the framing. Is there a procedure for disassembling these shelves (or a method of cleaning under the sealed edges?)
    Top Expert:
  • Sub-Zero Master
  • 9,472 Answers
I have taken mine out and soaked them in a stiff solution of bleach and water in the bathtub for an hour or so. Works every time for me.
Posted on Jan 02, 2011
How to remove the glass shelf for better cleaning PSC25MSSC
if the glass has plastict trim like pieces across the front and rear edges try pushing up on the glass close to the plastic trimat th rear end, the trim should swivel up and the glass pop out of the groove
May 03, 2015 | GE Refrigerators
Door slow closing sub zero 650
The door cams are worn under that door, this unit takes two, one for the door, the other for the hinge. They are different too.
Good Luck
Jan 30, 2013 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650: freezer drawer rollers squeak. Any ideas?
dry them off then spray with silicon.also good for cutain tracks.......plastic/metal.
Apr 09, 2010 | Sub-Zero 650 / O Bottom Freezer...
Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
Can i take apart the door shelves of my subzero for cleaning
You can take them off the door by lifting up and out at an angle but do not try to disassemble them. You can soak them in hot water to try and get rid of spills in the seams.
Jul 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
Clean front of Sub Zero
Try GOO Gone in either the liquid spray or the gel. This will not remove anything like paint or things like that. You can also use this on your cars finish and will not hurt it. So you are good to go
Feb 13, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub zero bottom freezer access
that unit must be 20 plus years old. There wouldn't be any diferent shelves available for it.
Jan 31, 2009 | Sub-Zero 650 / O Bottom Freezer...
Installing cams to sub zero 550
http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code is the locator area parts distributors. Once you get the parts in, remove everything from the door, food, shelves.... Then with the door closed remove the upper hinge. If you have a left hinge unit you can bend the shroud out of the way and bend it back when you are done. The door can be quite heavy if you have wood panels on it so you may need help. Open the door 90 degrees and lift up and over the bottom hinge. Remove the cam from the door using a phillips head screw. Then replace the hinge cam that is on the hinge that is still attached to the body. Now you will need help, lift the door up and have some one set it into the lower hinge pin. Close the door and have some one hold it closed while you climb up and reinstall the hinge. You may have to adjust the door by sliding it forward and back left and right until you get your sight line just right.
Dec 16, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero refrigerator freezes food
Hello. You need a new cabinet thermistor and while you are at it replace the evaporator thermistor. (The evaporator is the cooling coil behind the back wall of your fresh food section) . These sense the temperature in your frig. Both of them are behind the back wall of your fresh food compartment. You will need a wire crimper and a heat gun or lighter to heat shrink the wire connectors that come with the new ones.
Sep 20, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
247 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
