Laptop Mini eMachines eM250. when i start up the laptop the lcd stays white, very iluminated with no letters or nothing. just a bright light. i just replace the lcd for a new one, but it isnt the problem. the processor sound for a few seconds and then gets quiet. i connect an external lcd but nothing. i was thinking that maybe i can flash the bios with a USB or pendrive, but i need info about how to do it, so please if anyone has doing this, post the manual of procedure. thanks and sorry for my english, i am from dominican rep.
5 Suggested Answers
chrlygrn
  • 149 Answers
SOURCE: Dell Inspiron 5150 won't boot
have u checked the ram and made sure its functioning properly
Posted on Nov 11, 2008
  • 68 Answers
SOURCE: USB booting of external hard disk in HP laptop
You cannot boot Server 2003 from an external USB Hard Drive, it will have to be installed on an internal hard drive.
Posted on Dec 05, 2008
LaptopExpert
  • 458 Answers
SOURCE: HP DV6000 Laptop won't power on
HOW TO FIX YOUR DV6000/DV9000/DV2000
All the Problems described in the previous posts are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports.
Try to leave 1/4 inch area around the edge of the chip free of insulation.
To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness....
Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath.
You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING ....
Next You Will Need Some Coins.. Yes Coins..
8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top...
Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip...
The Reason for using the Coins: Using the coins serves a few purposes...
1) It Helps Transfers the heat Into The Chip More Evenly/Slowly
2) It Helps Hold The Heat Longer/Then Helps To Cool Slower
3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip
A Thing To Look Out For...
Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard...
This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges....
If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW...
Now Comes The Heating Of The Chip...
Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip...
Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever...
This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes..
Now Remove The Coins(carefull they might still be hot)
Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste...
Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video.... user_offline.gif report.gif
Posted on Nov 22, 2009
SOURCE: I bought tow eM250 series EMachine (ACER) mini
I also purchased two of these computers. I wiped the HDD and installed Win7 Ultimate. I could not get the wireless NIC driver to install. My solution was to use another wireless USB NIC and use Windows Update, Voila everything was fine. Iam writing this post with one of them. I am somewhat confused by your post referring to a Broadcom NIC. Both of my machines have AtherosAR5B5 wireless network adapters and Atheros AR9132 PCI-e Fast Internet Comtrolers. Broadcom has always meant Bluetooth driver to me, but I may be mistaken about that.
I have always thought of eMachines as being the cheapest in both price and quality but I did a rather extensive investigation on netbooks in general and could not find and justification for spending twice as much for a more popular name brand with basically the same capacities.
I don't know how to do one to one assistance on this site, but if you can figure it out I would be more than willing to help you. I am very pleased with these two netbooks!
Posted on Jan 21, 2010
What product key
Normally its on the bottom of the laptop with a Microsoft logo on it with a mix of letters and numbers. Its hard to miss. Also before you reload a system you can find the key with a software tool call key finder. Its free and safe. ^_^ hope this helps
Aug 16, 2014 | eMachines eM250-1915 Netbook
How can I upgrade my emachines em250 netbook?
To upgrade the motherboard? No. Just replace the laptop. If you want to upgrade, you may try memory, but it would take someone like me to look at it and see what upgrades might help.
May 05, 2014 | eMachines eM250-1915 Netbook
Emachine laptop goes white after logon
- First try to start pc in safe mode,by normally Pressing F8 key when windows starts up
- If you able to strt in safe mode then update your graphic drivers just go the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
- Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs and white screen
-If this didn't help you then simply get the Intel software partner Reginout to fix all the errors and registry issues which causing white screen
Jun 18, 2013 | eMachines eM250-1915 Netbook
My emachines em250 mini laptop says please input password for ST9250315AS
It has a hard drive password set. If you know the password then when you first boot the laptop go into the Bios and into security.. In there you will find where you can disable the hard drive password by entering it and choosing disable
Apr 21, 2013 | eMachines 10.1" LCD Screen for Em250-1162
Unable to boot emachine 350
It is possible the battery is an open circuit, so even with the power adapter plugged in there is not enough power to boot the machine. Laptop batteries last about 2-3 years.
Jan 13, 2012 | eMachines eM250-1915 Netbook
I have an emachines EM250 netbook (windows xp)that has a screen problem, on most monitors you have settings like cool and warn screen settings, well one of my netbooks out of 3 of them i own has the warm...
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Oct 26, 2011 | eMachines eM250-1915 Netbook
My emachine wont charge past 86% why?
Take to a laptop service center and check for battery leakage. Or any damage in the laptop. This is the only reason why your laptop might not charge properly.
Aug 26, 2010 | eMachines eM250-1915 Netbook
Jan 13, 2010 | eMachines eMD620-5133 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
