Question about Garden
King cat ride on mower model kr6905 16hp b&s vangaurd motor. Was mowing fine & engine simply stopped. Will turn over but won't start. Have cleaned spark plug air filter & fuel filter with no success. Any suggestions?
  • akschulz Jan 06, 2011
    Your explanations did not help at all. To understand what they all meant we would have had to be a mechanic. We have since had the problem fixed.
    President:
  • 2,468 Answers
Could be the spark ignition module,the flywheel sensor pick-up,a rusty flywheel thats so rusty that can no longer transfer spark impulse to the pick-up coil,an ignition wire or fuse in this circuit,or a bad ground in this circuitry too
Posted on Jan 02, 2011
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Turns off during mowing
It sound like its over heating try checking your thermostat
Dec 15, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Was mowing with riding mower was running fine started missing and black smoke coming out of exhaust stopped mower immediatetly oil in carb now and when try cranking it just cranks and cranks not firing
Pull plug and check compression. When cranking see if bottom pulley turns from engine. If compression is below 90 psi it won't start and you have an internal problem. Stopped mower immediately sounds like motor blew. Also check side of motor for cracked block, Good luck.
Mar 21, 2010 | Briggs & Stratton Garden
Murray Riding Motor Running but not Starting
does it have spark & gas let me know at wadembly@aol.com thanks,wade
Jun 07, 2009 | Garden
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
