Question about GE Monogram® ZET938 Electric Single Oven
Hi. We have a problem with our new, 3 month old, GE monogram 30" oven model ZET-1P-M3SS. In bake mode, if you set a temperature, say 375 for example, let it come up to temp, stabilize and bake for a while, then turn down the temperature, say to 350 for example, the LED temperature display goes BELOW the current or new temperature (actually to 320 when going from 375 to 350) The heating elements will then turn on, raising the inside temp up to about 400 before the elements turn off - after a long while, the temperature will eventually settle out at 350. I have verified this with an accurate oven thermometer. Why would the oven "think" it is 320 when it is at 375 and all I did was turn the knob to 350? Its the oddest behavior. This can't be normal can it? Is it a software bug? Have you see it before? Thanks, I look forward to hearing from you.
3 Suggested Answers
  • 3230 Answers
SOURCE: GE JTP 1580W288 Set oven to Bake, switches to broil at bake temp
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
good luck,
Posted on Jun 28, 2009
EllaWatson25
  • 725 Answers
SOURCE: Oven temp set to 375, reads 375; after 10 minutes
You need a new t-stat on this unit/ YOu can call us with the brand and model number and we can get the proper parts for you. Hope this helps you out! Thanks, Ella!~ :>)
Posted on Aug 18, 2009
GE Monogram 30" built-in oven turns itself off after a few seconds.
Likely you need a thermal cutoff replaced near where your heating elements are. It senses the fault and shuts down. You can but an after market thermal cutoff from most any electronic parts supply, and maybe even from an appliance parts supply.
Nov 12, 2013 | GE JTP20 Electric Single Oven
When the oven is set, it heats for about five minutes. Then "F-2" appears on the screen and it shuts itself off completely.
F2 Oven temperature is too high
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Dec 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
GE Monogram® ZET938 Electric Single Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
