Question about Technics SL-MC50 CD Player
Im not geting any sound out of the left side. Its not the speakers or receiver. I ve changed all the wire testing it. It is the left side of the cd player.
  • 1,557 Answers
The channels burn out its a common fault the quick fix is to buy a rca adaptor to run 1 output to 2 or replace the cd player it will cost a lot less to replace than fix
Posted on Jan 02, 2011
Pioneer receiver speaker b Left
The output transister is probally blowin for the left side,
Dec 02, 2012 | Pioneer Audio Players & Recorders
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
Warning levels
Hello
The (+ve) & (--ve) poles of the connection wires have neen reversed is the meaning. Just interchange the wires of each either at speaker box or at the output terminals of the amp. If these connection are reversed, the sound effect will vary in intesity. OK.
Jan 10, 2012 | Yamaha HTR-6130 Receiver
Trying to install my new home theatre
Are you sure the wire is not damaged somewhere? Are you sure that you are connecting the wire to the correct terminal on the receiver? Is the speaker OK?
To test all of this, try different combinations. With Right speaker working, disconnect the wire from speaker and connect it to the left speaker. If it doesn't work, then the left speaker is faulty.
Now disconnect the wire from receiver's right-front terminal and connect to left-front terminal. If it doesn't work, you are either connecting to wrong terminal or the terminal/receiver is faulty.
At last, try using the "left" wire to connect the rigth speaker to right terminal. If it doesn't work, the wire is faulty.
P.S. The +/- doesn't matter for testing, the sound should go either. It is just needed to have all speakers connected in the same polarity, because else the sound waves would eliminate themselves.
Oct 31, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
How do you install it correct
the audio source's output should connect to the inputs of the TS-WX11. caution on power supply connection: don't reverse the polarity of the positive and the negative wires.
Remember also to set your HU's output in order for it to work. If it does not work yet please give the details on your HU and other devices being used.
Aug 10, 2009 | Car Audio & Video
The left side sound is intermittent
Sounds like dirt in the volume control or a high resistance speaker wire.
Try switching the right and left speaker wires and see if the problem changes.
Aug 03, 2009 | Audio Players & Recorders
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
Left side speakers only one working
Have you reset the settings in the system to 5.1?Are the rest of the speakers working? Go over the wireing yourself just unplug one at a time and reseat it on both ends system end and speaker end it may just be that when he put it together again one of the wires wasn't set back just right.
Jul 14, 2008 | Onkyo TX-DS676 Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Technics SL-MC50 CD Player Logo
88 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
