Question about Sevylor Pressure Gauge Mano 4280A
I am at 3600 meters above the sea leveland my manometer is showing a preasure of 50 mbars...Is my device broken...how can I fix the problem
Sea level altitude
according to the elevation map its 25 meters or 83 feet above sea level
Mar 18, 2014 | Computers & Internet
Meter to kilometer
There are 1000 meters in a kilometer and 3600 seconds in an hour (60 seconds per minute, 60 minutes per hour).
Press 8 0 0 / 5 0 * 3 6 0 0 / 1 0 0 0 =
or 8 0 0 / 1 0 0 0 * 3 6 0 0 / 5 0 =
The result should be 57.6 kph.
Nov 11, 2011 | Casio FX-115ES Scientific Calculator
High voltage rpm power generator output
Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
Oct 10, 2011 | Coleman Powermate Powermate 5000W...
I can install the HC900 to 3600 meters above sea level?
Altitude should have no effect on the machine...
Just make sure to keep it clean so you get good airflow/cooling...
heatman101
May 09, 2011 | Mitsubishi HC900 Multimedia Projector
How to remove memory card
Remove the back panel of the phone, and on the Right side (Just below the USB port) of the is the memory card (SD micro) To get it out you just have to Push it down. When you release the preasure the memory card pops out and you can remove it. Hope this helps.
Jul 02, 2009 | Nokia 3600 slide Cellular Phone
Only half of the screen appears the other half shows a maze
Reads like the crystal is broken...
It is possible to have  the screen replaced in these devices, however the cost is normally above 50% of the original purchase price, of said device as the touchscreen is the most expensive part.
I never take mine out of the car unless it is in the protective case,(purchased separately) to prevent
this from happening. I've dropped mine twice. The $25 I paid for the case, is priceless given how much our 760 costs!
Mar 30, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Ique 3600 antenna reception problem
How long does it try to find the satellites? If it trys for a half hour of more with no results, the antenna may be broken. I have read in other forms that people have added an external antenna and their units would then work, evfen with the built in antenna broken.
Feb 25, 2009 | Garmin iQue 3600 GPS Receiver
Elevation Problem
Some models have the Barometric Altimeter which needs to be calibrated, and some units do not.
Vertical Accuracy of a properly calibrated Barometric Altimeter is +/- 10'. If you have a unit that uses provides a GPS Elevation only, a +/- 50' vertical solution is pretty standard.
Jun 22, 2008 | Garmin eTrex GPS Receiver
Broken screen
The best solution, in my opinion, is to buy a unit being sold for parts or repair (making sure that the LCD display was working) and do the replacement that way.
That's what I'm doing because when I write with my stylus it doesn't recognize what I write.
Dec 17, 2007 | Garmin iQue 3600 GPS Receiver
Sevylor Pressure Gauge Mano 4280A Logo
75 people viewed this question
Top Sevylor Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
ray gallant
Bill Boyd
Are you a Sevylor Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
