Question about Western Digital My Book (WDG1U2500) (G1U2500N) 250 GB Hard Drive
Just reconnected computer after a move and computer is not recognizing external hard drive now.
fire sine
  • 382 Answers
SOURCE: potable drive not recognized
What is your computer/Operating system?
Posted on Oct 22, 2007
SOURCE: External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
Posted on May 13, 2008
SOURCE: computer does not recognize simpletech
I have a simpletech external drive that was working, but after i disconnect it unproperlly, i was getting the message <usb not recongnize>. I called simpletech, but customer service is ****, and anyway the drive inside is a hitahi, i have another simpletech and the drive inside is a western digital, whatever...
They told be to go to best buy to make a recover, so i called and they told me it s 250$, and if they cant do it, they will send it to a labotory witch cost 1700$, crazy ******* hein?
I red about getting drivers, putting the hdd in a fridge and much more stupid thing, BUT THE SOLUTION IS SIMPLE, OPEN THE CASE, UNDER THE ALLUMINIUM STICKER THERE IS 2 SCREWS, REMOVE THEM, OPEN THE CASE, TAKE THE HDD INSIDE OUT AND REMOVE THE ADAPTER CONNECTED TO THE HDD(WHERE YOU CONNECT THE USB CABLE) CAUSE THIS IS THE PART CAUSING THE PROBLEM, THE HARD DRIVE IS OK AND YOU DIDN T LOOSE NOTHING. So now what you can do is just buy a new case for laptop hard drive (with a new usb adapter included), or buy another simpleshit hdd and switch the adapter part or just buy an adapter to make your hdd an usb hdd and Voila, and after that i suggest you buy yourself a better hdd than simpleShit and make a new backup.
Posted on Jul 25, 2009
graysand
  • 558 Answers
SOURCE: My computer is not recognizing my acomodata external hard drive
Can it work in another port or another computer?Try these option if all fails maybe the device is bad.
Posted on Oct 02, 2009
  • 355 Answers
SOURCE: samsung external hard drive not recognized
its happens when the hard drives cable or usb port is problem
change the ccable then try
other wise plug the pci usb card & first diseble the motherboards usb port
then try
ok bye..........................................
Posted on Nov 17, 2009
Samsung external hard drive
!! You have failed to provide a detailed problem. !!
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected.
Jan 29, 2013 | Samsung G2 Portable External HX-MU064DC/...
Pc does not recognize external drive
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
b>
Jan 07, 2013 | SmartDisk Verbatim 96867 2 TB External...
Imation 1TB USB external Hard Drive .....unrecognized in Windows Both in windows7 and XP.
Jan 07, 2013 | Imation 1TB Cartridge (IMN27957) Hard...
My iomega external hard drive light doesn't come on and my pc doesn't recognize it. I bounced the usb cable by accident and it came loose while i was listening to music from it. When i reconnected the...
When you disconnected the hard drive by pulling the USB cable from the computer without using the remove hardware feature it will cause the computer to not recognize the drive. You should be able to power down the drive and then re-boot the computer. After the computer has restarted then reconnect and power up the drive and windows should detect it again. Some of you files on the drive might have been corrupted when this happened so I would go into my computer and run check disk to repair any errors on the drive. If you reboot the computer and the drive still does not respond then you may have caused damage to the drive. You could then try dis-assembling the case for the hard drive and installing it into the computer and see if it works. If it works in the computer then the external hard drive's power supply is defective if it does not the the drive is damaged.
Nov 19, 2009 | Western Digital 500GB My Book Pro-External...
External hard drive not recognized
You need to first narrow down the problem to either your PC or the external hard drive. Do you have access to any other PCs you could try connecting your hard drive to? (think friends, family, public PCs, etc)
If the hard drive works on other PCs, we know it isn't a problem with the hard drive.
If it turns out that the hard drive is fine and the PC is the problem, I would suggest going in to Device Manager and uninstalling everything USB related. Once you have done this, either reboot your PC or right-click inside device manager and "scan for new hardware". All of your USB related devices should reload their drivers automatically. You may want to try this both with and without the usb drive connected.
Another tip would be to try various USB ports.
Mar 19, 2009 | Western Digital 500GB My Book World...
Does not recognize
Did you try the disk on a different computer to make sure the disk is functioning?
And if using a laptop, make sure that power is not an issue, an external power supply or 2 USB ports are always required.
Also check:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Maybe one of those troubleshooting suggestions can help you.
Jules
Mar 16, 2009 | Western Digital External USB 2.0 80 GB...
Maxtor External Hard Drive not recognized
you can find a program on the maxtor/seagate site maybe you can fix this with that..
Gr Rich
Jan 08, 2009 | Maxtor OneTouch III 500 GB Hard Drive
My computer doent recognize my external hard drive
disconnected from the computer and reconnect.
if it still doesn't recognized the device, disconnect and shut-off the power and wait 1 or 2 min. than re connect again.
with all that, if the machine still can't recognized the drive, then the drive need to be check with another work machine, make uure it is in working condition.
Dec 05, 2008 | Western Digital My Book Essential Edition...
The green light on my WD 500GB external hard drive started flashing and since then my computer has not recognized it. How do I fix this?
It is possible that the connection between the two drives is interrupted. If you really go the safest way, turn off your pc and disconnect your external drive. Reboot your pc and see if you when reconnecting your drive Windows finds it.
Nov 25, 2008 | Computers & Internet
EXTERNAL HARD DRIVE BY SIMPLE TECH 500 GG
First, check the warranty status. They should give you a replacement. The following will probably void your warranty... This external drive probably houses a standard hard drive used in a desktop computer. If you don't mind voiding your warranty, you could disassemble the protective "shell" and check to see that the cabling to the drive is properly attached. I've seen a external drive which the interface cable was partially unattached. If all looks OK here, you could remove the actual hard drive and try hooking it up to a standard desktop computer. If you or a friend is reasonably tech savvy, such is a plus. It could be set as a secondary drive, and then you could see if files could be accessed. If nothing above works, then your outlook is bleak. There are businesses specializing in file recovery from a dead drive, but it is expensive.
Aug 08, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
Western Digital My Book (WDG1U2500) (G1U2500N) 250 GB Hard Drive Logo
80 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
