Question about Nextar X3 GPS Receiver
The device does not come on even when plugged into the car charger
...I am on my 3rd GPS ...the first 2 were Nextar ..... guess what kind my current one is ...... certainly not another Nextar
Posted on Jan 17, 2011
Wont take a chargeIve
Either the battery or the charger is shot.
May 26, 2015 | Nextbook Premium 8 Se Android
My kindle is not charging
Is the device new or still under warranty? Is return to the store (RMA--"Return Merchandise Authorization"--through an online vendor) still possible? Extended warranty?
Is the charger (and outlet) OK? If you may attempt to use USB current from your PC/Laptop/etc., is that port workable and powered? Have you attempted an alternate method of charging? Is syncing then possible?
Chargers are not invulnerable--rarely, they sometimes overheat and die. After all, they're fabricated PRC items too--thus, even they may prove defective. (They're far less complex than a Kindle or phone, though--defective chargers thus prove quite rare.)
Chargers can't last indefinitely or through overly heavy use, either. (Chargers do tend to last longer than devices--failure proves quite rare!) Is the charger unusually hot after plug-in? (Such failure could prove a great danger to electronic devices. Very rarely, even fire or sparking is possible.) Is charger connection at the wall OK? (Is the outlet overloaded?)
Is it a "block" charger?: These may be replaced easily. Just get the connector and the Volts correct--with sufficient amperage (current). You don't need even to obtain the same brand and model as OEM--that which came originally with your charger. Online, amazon, Radio Shack, etc. may prove very helpful for such purposes.
Does the connector have sufficiently good contact through your Kindle's circuitry to its batteries? (Is the connection overly loose? Often, this occurs over time.)
Are you certain that the charging cable is OK? Does the connector in the Kindle need "doctoring" with a small tool, somehow? If the batteries are dead, it's likely possible to replace them.
It's possible that the device simply is dead (shorted-out)--power surge or fluctuation certainly are possible and likely culprits.
An extremely remote possibility is that the CPU or other key chipset is dead--even those prove useful for limited numbers of cycles. (Failure then implies quite extreme usage! Probably not!) It's not immortal!
Jun 28, 2014 | Amazon Kindle Wireless Reading Device
My garmin was working and the other day i plug it in the car charger in and now my garmin will not work while it is on the charger. If I take it off the charger it will work but not on the charger. what...
Does it show a picture of a satnav connected to a computer when plugged into the car charger? Sometimes this happens because the charger plug is not fully pushed into the back of the satnav even though it feels like it is. Pushing it in further may solve the problem.
Jul 14, 2011 | Garmin nuvi 250W GPS Receiver
How long do i charge,does car have to be running to charge?
Charge time depends on brand and model of your GPS. I'd say between two and six hours. For most GPS devices you can just keep the charger connected to the device and only remove it when you park the car in a place where theft is possible. When connected to the charger, the device should be running even if the battery is depleted.
If you connect to a cigarette lighter plug, the car does not need to be running, but the electricity must be switched on, i.e. key inside and turned into first position.
If you have a GPS mounted fixed into the console, there is no generic answer, in most cases, I guess, it is the same as with the cigarette lighter chargers.
Dec 31, 2010 | GPS
I received a Garmin Nuvi 255w as a gift back in October 2009. I am a Realtor and use this almost every day. Yesterday I was driving around, and I did have the Garmin charging with the car charger. In the...
The unit should still operate and turn on even with a dead battery when connected to an external power source such as the DC car charger, AC wall charger or USB cable (connected to a PC).
Please try the reset procedure listed here:
http://www.sharc.net/discus/messages/6/313.html?1269314749
- Jim
Mar 26, 2010 | Garmin nuvi 255W GPS Receiver
My magellen 3100 battery will not charge
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
I have a Garmin 760 did not come with a ac
The AC charger plugs into the mini-USB port on the bottom of the unit. The term AC is somewhat misleading as the AC charger plugs into an AC outlet but provides +5VDC to charge the units internal 3.7VDC battery.
You can purchase an OEM AC charger here:
http://www.sharc.net/gps_repair_prices.htm
- Jim
Aug 23, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin 200 won't turn on, flashes "Garmin" screen when plugged in
I connected the unit to the car charger instead of the USB charger and then held down the reset for 10-15 seconds, after which the system would show the computer connection on the charger and then boot up when not on the charger.
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
Does leaving a cell phone charger plugged in to an outlet at home,without having the phone charging in it,drain energy from your home?
Yes. You are right. Here energy is not the criteria. It is always safe to unplug the charger (when not in use) to prevent the damage of a cell phone due to accidental over load of electricity or short circuits. Moreover Chargers do draw power when plugged in, whether or not a device is actually being charged.
If the charger is plugged in someplace easy to access, like right by where you keep your phone, you should unplug it. But if it would be difficult to have to plug it in every time you need to use it, you'll be fine just leaving it plugged in..and.It still uses energy even when not charging. Any electronic device plugged in a socket uses energy whether it is in use or not.
Oct 07, 2008 | Samsung SGH-D900 Cellular Phone
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
Nextar X3 GPS Receiver Logo
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
