My touchpad on my Toshiba A215-S7428 is acting erratically. I've already gone into the settings and changed the zones but if I hover over any icon it will open it without any tapping -- help!!
    Novelist:
    Scholar:
  • 158 Answers
Uninstall the touchpad drivers and reboot laptop use an usb mouse to remove drivers as this will be needed.
then it should reload drivers and all will be fine if not then goto Toshiba's website and download the touchpad drivers and install then reboot laptop all should be fine.
and be very carefull when you are near the touchpad as the buttons are easily pressed.
good luck
Posted on Jul 09, 2008
Toshiba a215-s7437 touchpad will not work
Use a USB mouse for the meantime and try doing a system restore to a date when it was working fine before How to perform system restore (https://www.youtube.com/watch?v=oGXbMyFaROw)
If system restore did not resolve the issue then try uninstalling and reinstalling the driver for your touchpad.
You can go to toshiba website and download their latest touchpad drivers for your a215-s7437.
hope this helps.
Thank you
Sep 08, 2014 | Toshiba Satellite Computers & Internet
Tip
Drivers problem
can't find vga drivers for toshiba a215-s7428
on May 17, 2010 | Computers & Internet
Connect sony handycam dcr-dvd201e to laptop toshiba sat a215-s7428
Use Sony Vegas software to download the videos..
There is as option on File, Import, import from DVD camcorder disk
good luck
Sep 07, 2013 | Toshiba Satellite A105 Notebook
How do I unlock my Toshiba Satellite A215-S7428 PSAFGU-02E002
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Oct 10, 2012 | Computers & Internet
Monitor flickers then goes black
Your screen needs to be replaced. It is dying.
Aug 18, 2012 | Computers & Internet
My touchpad can be a key
yes it can, tap it to make it act like a right click mouse
Jun 20, 2011 | Toshiba Satellite A215-S7462 Laptop
Cursor does not move when running my finger over the touch pad. Thank You Bill
1. Adjust the touchpad sensitivity from the control panel. Perhaps lessening the sensitivity will solve the problem. In Windows OS go to your control panel, and select hardware and sound. Then click "mouse," and when the new window pops up select the settings tab. From there you can adjust the sensitivity. If your mouse came with its own software you may be able to adjust the settings from the system panel. Hover your mouse over the icons near the system clock, and look for an icon that is titled touchpad, or mouse. You can click this icon and adjust settings.
2. Clean the touchpad with rubbing alcohol in case there is a grease buildup on the touchpad. This is the most common cause for touchpad failure.
3. Remove the touchpad drivers from device manager and reinstall. Sometimes there can be driver errors that are preventing the touchpad from working. Device manager can be accessed via control panel in Windows systems.
4. Replace the touchpad if none of these steps work. Prices can range from $15 to $50 plus labor rates. It is best to let a computer professional change this since major disassembly is required to remove and replace the touchpad, and many fragile components will be exposed during this process.
Hope this help. Goodluck!
Mar 28, 2011 | Computers & Internet
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Toshiba satellite touchpad
READ THIS POST NOT THE OTHERS. you can configure each of the four corners of the TouchPad surface to act as different buttons when tapped. These corner regions are called Tap Zones. to disable this feature goto control panel, mouse, device settings, settings, tapping, tap zones, disable tap zones.
Feb 17, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
