Question about LG DLE2101 Electric Dryer
My dryer shut off and the display forms a rotating circle can not be cleared unless the dryer is shut off.
3 Suggested Answers
miket756
  • 2702 Answers
SOURCE: My dryer won't rotate unless I give the drum a
its the drive belt slipping it needs a new one fitted
Posted on Nov 10, 2009
MNTECH
  • 1543 Answers
SOURCE: the dryer is louder than
The rotating circle was just that someone selected "wrinkel care" as an option, which will turn the dryer on for a 10 second no heat tumble every 6 minutes after the regular cycle is done. It will continue that until the door is opened or power is turned off for up to 3 hours.
Noises could be drum support roller(s) or objects caught in the felt drum seal.
Posted on Mar 13, 2011
My Dryer start and stop in normal circle
Is this electric or gas----does the tub stop rotating or does the whole machine shut down?---if so there's a good chance that's it's overheating, safety shut down to eliminate a fire and in addition, the dryer vent is possibly plugged or restricted.
Oct 09, 2014 | Kenmore Dryers
Samsung front loading dryer the display shows rotating circle rather than time remaining
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
Jul 28, 2014 | Washing Machines
Bobbin thread gets jammed
Is it forming a stitch at all? Do you have your needle set properly and are you certain it is the correct size. it sounds like the hook isn't catching the loop formed by the needle. If changing the needle doesn't help. it might be time for a clean and adjust.
Dec 14, 2012 | Kenmore Sewing Machines
Dryer runs for about 5 minutes then shuts off. It gets hot and drum rotates but it keeps shutting off. Then it takes about a half hour before it will start again.
It sounds like you're not getting good airflow and thus tripping the thermistor. Make sure all the vents are clear and the lint trap is clean.
Mar 07, 2011 | Roper REX5635E Dryer
Neptune dryer runs then shutsoff then starts again
probably bad computer board expensive repair hope you love the machine
Mar 30, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer says 8.8. on display
Put a heating pad over the display panel. After 5 - 10 minutes, the display panel will return to normal and the dryer will work,
Jan 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Nov 10, 2009 | LG Dryers
My maytag gas dryer timer does not turn, does not get hot, does not shut off unless I shut it, why?
HI. This will occur when the timer mechanism(timer motor assembly), becomes fused, or the motor itself has failed. The timer mech is the main initiator of all the selected cycles. If the timer is unable to rotate properly, the unit will not heat or stop as well. Replacing this defective timer module will correct this issue.
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Amana dryer timer dial wiil not rotate/temperature stays hot
The elctrical contacts in the timer have welded themselves together or the notch wheel is broke in the timer; either way you need a new timer, and this also explains why it runs until you open the door.
Apr 10, 2009 | Amana NDG7800AW Gas Dryer
Problem when drying gets to 1 minute mark
This is happening when you selected the wrinkle prevent option or you set it to wrinkle release cycle.what it does is it is tumbling with no heat to release the wrinkle in the clothing. This is normal.It could also be normal part of drying in "regular" cycle
May 29, 2007 | Maytag Neptune MDE6700A Electric Dryer
LG DLE2101 Electric Dryer Logo
414 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
