Question about Samsung HW-C560S Theater System
HW-C560S AV Receiver message display PROTECTION. I unplugged and plugged back in and still PROTECTION message. Is it time to take to shop? I know nothing about electronics.
  • Samsung Master
  • 2,098 Answers
Your set is in trouble my dear friend.
Protection will appear because the processor sense that you have a faulty parts on your unit.
To avoid further damaged, your system shut it off automatically.
The main reason is your Power amplifier I.C., it is shorted,need a replacement.
I"ve strongly adviced you to look for a qualified technician or electronic shop to fix your problem.
Good day!
Posted on Jan 02, 2011
How do I reset a technics sa-gx350 receiver unit
Don't know that you can actually reset this unit like the new digital receivers. It does have protection circuitry that will shut the unit down in case speaker wires are shorted or if speaker impedance is less than the indicated rated impedance of the amp. do the following:
1. Turn off power and unplug from wall.
2. Check all connections and correct if needed.
3. Turn back on after 1-2 minutes.
If unit is still in protect mode you may want to unplug everything from the unit and then power back up to see if the problem is internal or external. If it powers up correctly then the problem is external. Power back down and plug in one external item at a time and power back up between connecting each item to see which item causes the receiver to go into protection mode.
If problem seems to be internal I'd recommend taking to an electronics repair shop if you aren't comfortable with taking apart to check fuses, terminations, etc. There may be a 5-amp fuse in the power plug head also.
Oct 21, 2013 | Audio Players & Recorders
I just picked up the Samsung HW C560S receiver. I'm trying to run a cable box as well as a blue ray player through it connected by HDMI. Blue Ray seems to work fine but can not get picture from cable box....
When you run the cable box and the blue ray player to your receiver you use two sets or cords yes? there for you need to run two sets of cords to your TV from the receiver. Have you done this? Both the DVD and Cable box will have different inputs to the TV. Turn the cable box on and cycle through the inputs on the TV. One should pop up for the DVD and a different one for the cable. Let me know if this works.
Mar 07, 2011 | Samsung HW-C560S Theater System
Samsung HW-C560s receiver is not responding to the remote, but remote is working fine
I had the same issue and wasn't able to find a solution on the net.... I got it working again by setting the remote to the receiver setting (amp in orange) then held down the power button and the number 1 button at the same time for a few seconds. It now works perfectly again.
Feb 10, 2011 | Audio Players & Recorders
I have a pioneer vsx 2016. I'm facing an overheating problems on the AV. Just switch on the AV for 10 minutes and the overheat messag will appear on AV screen and the device will shut of.
http://audio.manualsonline.com/search.html?q=vsx2016
Does it indicate a problem with the fan? (Page 67)
FAN STOP
blinks in the display, then the power automatically switches off.
• Something is obstructing the fan. Remove the obstruction and try switching the receiver back on. If the
fan is still not working, or you can't remove the object, unplug the receiver from the wall and call a Pioneer
authorized independent service company.
• The fan is malfunctioning. Unplug the receiver from the wall and call a Pioneer authorized independent
service company.
Check for dust balls in and around it. Disconenct power before exploring inside.
Feb 07, 2011 | Pioneer VSX-2016 7.1 Channels Receiver
My Yamaha RX V461 receiver will not turn on. When pressing the ON/STBY button, I hear the familiar "click" when pressing the button and a second one about 1-2 seconds later that comes from the...
Your receiver probably went into protect mode because you were overloading the output stage with concert blast. In some units, protection consists of fuses that blow; in others protection is provided by thermal shutdown devices.
Mar 04, 2017 | Yamaha RX-V461 AV Receiver
Trying to hook up sony s-master with componet cables an the s-master displays on the display ''PROTECT UNPLUG'' however with nothing plugged in the s-master, works fine
Check speaker wires, any wire seems shorted and causing Protect Unplug error message in receiver.
Good way to sort out bad wire is plug one speaker at a time, turn On receiver check, turn Off, then plug next speaker wire until you find out what speaker wire activates protection circuit of receiver.
Thanks.
Jan 01, 2011 | Audio Players & Recorders
Denon AV Receiver Model AVR3600 locked at'' Protection '' mode
The power supply is damaged and needs to be serviced. You have done exactly what you should have to test for an outside issue, it's the receiver.
Nov 02, 2009 | Audio Players & Recorders
NAD AV-716 receiver
I just tried turning off selective tone and it is now working.
Dec 01, 2007 | Audio Players & Recorders
Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Jun 06, 2007 | Yamaha RX-V630 Receiver
Samsung HW-C560S Theater System Logo
292 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
