Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Convergence I just changed the convergence ICs in my Hitachi and the problem wasn't fixed, red can't be adjusted, any idea? Resistors are not burned out.
  • 7 more comments
  • denis-tech Jul 31, 2008
    Thanks for the info, I really did check all of the resistor carefully, so it must be something else? When trying to adjust the convergence I still can't do it with the magic focus (manual or automatic). I'm thinking going into the service menu, I bought the service manual but it's not telling anything about the codes in the menu. I'm running out of ideas with this tv, what started out as a little project has turned into longs hours. The tv techs want to charge some hundred dollars just to look at it, myself being an electronics technologist thought of being capable of solving the problems. The red color is the problem, it's coming out to the left horizontally doing a gost like image to the left. Have any idea which part I could check for this red problem? Thanks a bunch
  • denis-tech Aug 02, 2008
    ok so I checked resistors: RK46, RK42, RK50, RK54, RK58, RK62, RK63, RK43, Rk47........all are good out of circuit and in the 5% tolerance........what now?
  • denis-tech Aug 03, 2008
    I did not check the jumpers yet, I'm kinda confused as to where I measure these voltages that you outlined above, between which points should I measure, as in where should i position both leads of my voltmeter? I guess what I'm looking is a common grounding point.
    Whats a cold ground point?
  • denis-tech Aug 04, 2008
    ok so I was measuring voltages as you described above, went to measure at QK01, all of a sudden TV shuts off, I go to put it back on,turns on for like a second shuts off again, and now it keeps doing this over and over, what happened?
  • denis-tech Aug 05, 2008
    I am using a digital voltmeter yes, but I did try unplugging the set, doesn't help, tv turns on then shuts off, seems like the flyback wont fire the bulbs I don't know.
  • denis-tech Aug 06, 2008
    Nothing is glowing, all that happens is I'm hearing a clicking sound, the Tv is trying to turn on but doesn't. I can see two green LED turning on will this clicking sound happens then they turn off. The transformer does not turn on at all, little noise coming from it but thats it.
  • charmouta Sep 02, 2008
    i have a similar problem but seam like all three colors are out out of line.
    any suggestions
  • Anonymous Apr 21, 2009
    Red line can not be adjusted.
  • 21 Answers
If the the TV is shutting down now meaning it is going to protection mode and it is cause of high current due to short circuit.
Go back from the beging and double check if did not accideentally short anything when doing the voltage check, also check the horizontal out put thransistor if it's ok.
When changing convergence IC you should have check all the voltage before removing the old one to make that there is no open resistor or shorted diode ans so on, as you mention you got the service manual for it and if you are familiar with schematic diagram it will tell you pin by pin if how much voltage are present.
FYI - Convergence IC's has 2 votalges - negative and + possitive.
Good luck.
Posted on Mar 11, 2009
  • Hitachi Master
  • 8,617 Answers
Did you check the resitors out of circuit? As its very rare when a Hitachi doesnt open at least two on the affected circuit. If you checked the resistors in circuit an open resitor will read good even though its actually open.
Posted on Jul 31, 2008
  • 4 more comments
  • Sonny Berry
    Sonny Berry Jul 31, 2008
    Ok heres how Hitachi DCU systems work. If the red has shifted horizontally you have to check the red Vertical. Verify that RK46 is within 5% tolerance checked out of circuit. Then check the DCU voltages at jumper K273 for +5V if bad check IKo1 for +7v
    Then check DCU jumper K274 for -5v if bad Check QK01 for -7v. if both the jumpers are good then Check IK04, and IK05 pin 5 for +30 - +33V if bad check FK01. then check. Then check pin 4 of IK04, and IK05 for -30 - -33V if bad check FK02. If you get the Plus and negative voltages off the pins 4 and 5 of the two ICs then it has to be RK 42, 46, 50, 54 ,58 or RK62 is either opened or outside of the 5% allowable tolerance.
  • Sonny Berry
    Sonny Berry Aug 02, 2008
    Did you check the DCU jumpers as outlined above as that wll determine if the DCU is defective or not.
  • Sonny Berry
    Sonny Berry Aug 03, 2008
    The jumpers are just a strand of wire thet jumps the circuit. use any cold ground point.
  • Sonny Berry
    Any heat sink will be a cold ground.
  • Sonny Berry
    Sonny Berry Aug 05, 2008
    Are you using a digital ohms meter? If so the battery could have shut off the transistor. Try unplugging the set and then replug it in.
  • Sonny Berry
    Can you tell if the heaters are glowing in the neck of the Tubes?
The fix is that Hitachi is a POS. It's kinda like a FORD product, found on road dead. There are problems all over the internet with Hitachi TV's. I ain't gonna give up on putting them down until they fix my 3 1/2 old TV with most of the problems you people are describing.
Posted on Oct 27, 2008
I have a hitachi 53fdx01b projection tv. The colors are shifted and droop downward. the cross hairs don't move when I try the convergence adjustment. Will new chips fix the problem?
If trying to adjust the convergence doesn't work, then is the convergence ICs that are defective. I would suggest to inspect all the solder joints on the ICs and resistors for possible cold solder joints. If everything looks good then replace both ICs and also measure resistors that are connected to the convergence ICs.
Let me know if you require further assistance.
Sep 13, 2015 | Hitachi Televison & Video
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
Magic focus does not work. RGB projections do not line up.
That symptom is usually caused when the convergence ICs and associated resistors fail. You can get convergence repair kits for the various Hitachi models from www.tvrepairworld.com the kids contains both ICs and the associated resistors plus the CD with repair instructions.
Jan 07, 2011 | Hitachi Televison & Video
Can a hitachi convergence be fixed without a remote? seems like red is adjustable, but cannot access the blue line with our universal remote
Ur universal remote was able to move - + from the convergence grid wright,it is a good remote.The tv convergence board is dead.The tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead too.These parts must be replaced on the tv convergence board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 19, 2010 | Hitachi 43FDX01B TV
I have a 53 inch hitachi ultravision #53UDX10B Its out of focus and when you press the magic focus button it trys then pops up with the # 4 in the corner is this a convergence problem or what ?
Yes, you have a convergence failure. Usually requires replacement of 2 X STK ICs and any burnt resistors associated with the function that is faulty.
Look at the user menu and compare with images on our Convergence Gallery. Try to adjust in the convergence adjust menu. Identify the functions that do not work and make note. When you replace the ICs, pay special attention to the low ohm resistors for the non-working function. They will be located near the colored plug associated with the non-working function. If red vertical will not adjust, check resistors near the red plug.
There are many posts and websites that offer "new and improved Convergence IC substitutes. My advice is to use the original part numbers and replace any burnt resistors with original values. Many ICs purchased on the Internet are very poor quality and do not work. Many users get substitute replacement ICs and never get their TVs working again.
If you have other electronics repair experience, this job may be done with some chance of success. If you have no experience, there are many secondary problems that can and usually do appear. Determining how to fix the secondary faults and how to correctly align the TV is difficult without prior convergence repair experience.
Some of the common problems encountered are:
1. Poor solder techniques, resulting in damaged PC boards or poor solder connections.
2. Poor quality or wrong parts installed and recognizing this problem.
3. Resistors open or burnt. Some resistors are weakened by the initial faulty IC. Replacing with a "good" IC and starting the TV causes the weakened resistors to burn up. IC may be ok but there are one or more open resistors that measured ok when ICs were being replaced.
4. Wrong ICs used, causing resistors to burn up.
5. Resistors that measure normal and become faulty when heated by current flow.
6. Recognizing that convergence circuit is repaired correctly and alignment is needed.
7. Major alignment in service menu required because data is corrupted by multiple tries of magic focus or manual adjustment while faulty circuit conditions exist.
8. Major alignment required because user adjusted centering rings or physically changed mechanical focus adjustment, then mis-adjusted convergence settings trying to correct mechanical alignment faults.
9. User has not connected plugs and connectors correctly and caused secondary damage or mis-alignment trying to correct secondary issue.
Physically replacing the ICs may appear simple but recognizing if a fault still exists or if correct repair is required causes many attempts at repair to fail. Keep it simple. Replace with good quality original part numbers, measure suspect resistors and adjust only what is necessary.
There are only 3 things to fix, IC failure, resistor failure and user induced secondary faults. Data processor and memory is bulletproof.
easyab
Apr 22, 2010 | Hitachi 53UDX10B 53" Rear Projection...
It appears the television has a convergence problem. I am pretty sure the red color does not line up with the blue and green. Is there a way to adjust the red manually? The magic focus does not fix the...
No not adjustable,Ur convergence it dead.Must replaced the 2 convergence ICS,and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit to repair it ur self.The shop well cost U $300 for parts and labors.
Feb 06, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Convergence repair problems.
alot of people make the mistake of putting two STK392-150 Ics in the Hitachi , and most times it will not work unless you change all the convergence resistors.. If youre going to upgrade hitachi to anything other than the stock ICs, it is recomended by Hitachi to use the STK394-160 ICs but then you have to change the ratings on the resistors. You can get the upgrade kit for your hitachi at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Dec 25, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
314 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
