Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Cant delete files off external harddrive. files disappear but no space is freed up? lacie porche fa
  • Jeffrey Groves
    Jeffrey Groves Jan 02, 2011
    Have you emptied your recycle bin or trash can?
    Scholar:
  • 80 Answers
this sometimes happens when you delete files partially. Deleting file normally will send it to the Trash (MAC) or Recycle Bin (PC) . The file is not really deleted at that point. Make sure to empty the Trash or Recycle Bin and the space should be freed.
If this does not work, copy all needed files somewhere else, then format the drive.
Regards,
Posted on Jan 12, 2011
Delete lacie files
Please specific what OS you are using. Also is the drive internal or external.
Sep 24, 2014 | LaCie Computers & Internet
Message on LaCie Hard drive says Hard Drive is full, but I cannot clear
Ensure that your system drive C: is not full, or you get similar troubles. When the external hard drive start giving this kind of troubles usually it is becouse of a bad FAT, the only solution is formatting the hard drive. Store your 15 GB elsewhere and format it.
Jul 29, 2008 | Computers & Internet
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Sometimes the hard drive will connect and sometimes it won't.
There have been problems plaguing the LaCie external harddrives, for quite some time now.
The issue directly relates to the interface, inside the external enclosure. I don't know if you are acquainted with harddrive designs, or the interface that they plug into. If you are, disregard the following.
This is an average example of an IDE harddrive, http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Looking at this illustration, note where it points to -> IDE Connector. The illustration isn't very good, but those dots are metal pins.
The connection inside your external harddrive,
that connects to the harddrive itself, is called an Interface. This is a plug that has socket holes, to match those metal pins.
Now we go a little deeper. There are two types of harddrives. One is an IDE harddrive, the other type is a SATA harddrive. Your LaCie
will have a SATA harddrive inside.
Instead of the 40 pins that an IDE harddrive has, the interface for a SATA harddrive has 7.
(It has 15 pins for the power connection)
Now my solution:
Should you wish to save data that is on your LaCie external harddrive right now, I suggest you buy an external enclosure, (SATA), take out the hardrdive thats in your LaCie, and install it in the enclosure.
Since, the dimensions of the, LaCie design by Porsche 160GB external harddrive are:
Height -> 1.4 inches, (About 1-1/2 inches)
Width -> 4.4 inches, (About 4-1/2 inches)
Length -> 7.4 inches, (About 7-1/2 inches),
I'm willing to bet the harddrive inside is a desktop harddrive size. (3.5 inches across in width)
http://www.lacie.com/download/datasheet/porsche_hd_en.pdf
These are examples of 3.5 inch SATA external enclosures,
(A $25 or $35 unit will work just fine)
Jul 18, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie Hard Drive, FA Porsche model
If the disk is FULL then you have used all the space, this is not uaually a fault but you may need to look at the data on there and delete any old stuff you dont need. IF you need it all then you should buy a larger capacity drive.
use "my computer" to see the drives connected to your PC. The lacie should be easily identified by it's name. Double click on the drive and you can explore the files/folders.
HIH
May 06, 2008 | LaCie F.A. Porsche (301177) Hard Drive
Creating space on external hard drive
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
512 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
