Question about Dryers
The dryer keeps shutting down. i toke the filtre out and noticed water standing in the rear pan of the dryer. can this be a pump or clog issue?
  • 50 Answers
It sounds like your dryer is not venting properly. Remove the vent hose from the back of the dryer and test the dryer again to see if it shuts down. If it is normal with the vent hose off your vent pipe is plugged.
Posted on Jan 02, 2011
Hi. i have a kenmore french door bottom freezer refrigerator thats leaking in the back of the fridge part. is it a clog in the evaporator drain tube? its all a big sheet of ice from it leaking.
remove back panel of refrigerator. use hair dryer to melt ice in drain pan under evaporator. keep thawing drain and pouring hot water down it till water runs down and clears drain tube.
May 07, 2017 | Kenmore Refrigerators
My Front Load Affinity washer shuts off after a few minutes
Good Afternoon Lori - Thank you for your post! Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, then once again it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 11, 2013 | Frigidaire Affinity ATF7000E Front Load...
Ice builds up in freezer bottom pan, not going down the drain tube. Is this an indicator of the defrost timer not working correctly, and if so where is the drfrost timer on a ETIFTTXKT02 model?
Defrost timer is working or there would not be water/ice in the bottom pan (as you describe it.). Check that the drain tube from the pan to the bottom evaproation tray under the refrigerator is clear of restriction.
Dec 14, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaks from somewhere in the freezer and collects in the bottom where it freezes. How can I make it stop? It gets so thick it leaks out the front and make a puddles on the floor. I have to take a hair...
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
Nov 15, 2009 | Jenn-Air JCD2389G Side by Side...
Sharp CV-P10NC AC unit it has a puddle of water coming down.
earlier models had a pan you had to empty .. your model has a small pump that is supposed to pump the water out the hot air vent (that goes thru the window} .. since its leaking it is likely that the pump inlet is clogged ... you might have to remove a panel to get at that ... it will be near the bottom of the unit (near the drainage nozzle) ... also check the hose that goes out thru the outside vent .. make sure its not cracked, clogged or smashed ... temporarily you can use the drain nozzle to drain off the water to a lower area (it cant drain up without the pump) ...
Aug 17, 2009 | Sharp CV-P09FX Air Conditioner
Will fill with water but will not wash or spin. than has a code nd
HI, your machine if programed to shut down if there is a drain issue. this (nd) code represents a drainage issue. check the drain hose for kinks and, make sure the stand pipe isn't clogged.
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 20, 2009 | Maytag Washing Machines
Water is not draining into pan. it is going inside fridge under
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 17, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ruud UBHC17J11NFA: Condensate pan filling up - condensate pump works fine
blow out the drain line from the coil to the pump the clog is there causing the pan to fill up and trip off
Apr 28, 2008 | Ruud UBHC Air Conditioner
Ariston margherita wont drain and selector knob keeps turning
Plug off the wall first. The spin normally does not work when the outlet filter is clogged; be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
Nov 29, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Asko T780 Stopping after a few seconds.
It sounds like you have a condensing dryer. These condense the water into a pan in the back, and then the water is pumped down the drain. If you are getting an overflow, it means the pan is full of water and the controller is shutting it down to prevent it from leaking on the floor. Most likely cause is a bad drain pump, which is a bit of a bear to change as it is in the back behind the rear wall in the lower right hand corner. The other option is that the drain line could be pinched or clogged, especialy if the unit was moved just before the problem started. Hope this helps!
Mar 12, 2007 | Asko T780 Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
