Question about Solar Heating System For Swimming Pools
What does error 77 mean with a supreme solar heating
A broken or disconnected pool sensor cable
Posted on Nov 22, 2011
Why does our solar water geyser not heating from the sun yet it heats from electricity?
For any type of water heating issue, please contact Northern Lights Solar Solutions. Call 1 -800 -317 -9054 or email info@solartubs.com your concern. They will definitely get back to you.
Northern Lights Solar Heating Solutions Solar Water Heaters
Aug 04, 2014 | Solartech Power Solartech 85 Watt...
Tip
Solar Air Heating - You Can Cut Utility Costs and Save Money
Solar energy is becoming very quickly recognized as one of the best alternatives to fossil fuels It is an abundant and renewable natural resource. It can be used to save energy in residential, commercial, and industrial settings. Solar technologies will use the sun's energy to provide heat, hot water, light, electricity, and cooling, for homes, businesses, and industry.
Many major advancements have been made in the solar technology fields over the recent years. Solar air heating is becoming more attractive than ever before now that it is becoming lower in cost and more efficient. Solar energy is easily the cleanest and most inexhaustible of any of the known energy sources. The many variations in energy prices have fueled interest in alternative fuels such as solar energy. Demand for solar energy has been increasing exponentially as heating, cooling and many other energy costs continue to skyrocket.
Solar air heating and solar water heating are two examples of solar thermal technologies which produce heat, but not electricity. Solar air heat is best suited for installation in new construction and existing houses. Solar panels for any type of heating should be placed on a south-facing pitched roof, free of shade. The angle should be between 20 and 50 degrees. They may also be mounted on an angled frame on the ground or on a flat roof. Solar air collectors (the devices that heat up the air using solar energy) can directly heat individual rooms. They also can potentially pre-heat the air passing into a heat recovery ventilator or the air of an air-source heat pump. Solar heating panels can be one of the most cost effective ways to reduce your utility bills. This will make a positive contribution towards a better environment. Solar air heating systems often use large bins filled with rocks that store heat (although this method is becoming rare due to problems associated with controlling moisture and mold growth in the rock).
Energy Policy Act has implemented a 30% tax credit for consumers who chose to install solar water heating systems. State and local government programs are now being put in place to encourage the use of solar energy. Cash incentives are available for those that integrate solar energy technology as an alternative energy source. The Department of Energy (DOE) is working to design even more cost-effective solar heating systems and to improve the longevity of the materials used in those systems. Other incentive programs now include offering homeowners tax credits for solar panel installations and for solar heating systems. With solar power you will save money, increase your property value, help protect the environment and help to create a more secure America by reducing our dependence on foreign energy fuel sources.
A great solar heating system will save energy, reduce utility costs, and produce clean energy.
on Dec 12, 2009 | Heating & Cooling
What does a 77 error code on a Bernina sewing machine mean?
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
Mar 28, 2012 | Sewing Machines
We just bought a house with an AquaStar II solar pool heater, when we try to adjust the temperature we get a flashing check sensor error. Can anybody help us find the sensors or how to fix it?
On the Goldline controllers, the check sensor light flashing means the sensor on the roof is either bad, disconnected or shorted out. When the check sensor light is solid on, that indicates it is the pool sensor. Check the wiring from the controller to the sensor on the roof. If the wiring is not damaged, most likely you will need to replace the sensor. You can check the sensor with an ohmeter, it should register 10,000 ohms at 77 degrees.
Oct 02, 2011 | Water Heaters
I have an error code S2. what does that mean?
Did you ever get an answer.
I get the same error code. "S2"
Jan 09, 2011 | Fafco 2 PANEL DELUXE SOLAR HEATING SYSTEM(...
MACHINE ERROR 77
You have a defective fuser unit, not heating up.
Jun 22, 2010 | Brother IntelliFax-4100e Fax
Message on machine states error 77, unplug and call brother?
Error 77 basically means- Heater thermistor short circuit. However, the message is sometimes incorrectly shown. You can try this- power off the machine, take out the cartridge, close the door and power up. The machine should notice either the toner or the front door is not in place. Now open the door and place the toner. This might solve the problem. You can also try to soft reset the printer. If none of these works, you might have to change the thermistor.
Apr 06, 2010 | Brother MFC 9700 All-In-One Laser Printer
Have a supreme Solar - Solar conroller for swimming pool. Roof indicator light is flashing and system wont turn on, (not even in manual mode) Pump working OK though. What does this mean
it sounds like you have a problem with the air temperature sensor on the roof. either you have some damage to the wiring going to the sensor, or the sensor itself has gone bad. Also, check the wiring inside the control box, make sure the connections are tight. If possible, follow the wire from the control box all the way to the sensor. If the wire looks good and there is no damage at all, the sensor probably needs to be replaced.
Nov 08, 2009 | Solar Heating System For Swimming Pools
Machine error 77
the fuser unit (fixing unit) not registering heat requirement. The heat roller or the thermistor sensor is defective.Remove fuser and check roller, if good replace sensor, reinstall fuser and reset machine.
Aug 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Error 77
related to a fuser error. Unit is detecting a too high or low heat internally. Try turning off for a few minutes. If error returns check voltage level at outlet or try a different outlet. Maybe too many items plugged in same outlet. If error returns, may need new fuser or thermistor.
May 09, 2008 | Brother IntelliFAX 4100 Laser Fax
Solar Heating System For Swimming Pools Logo
239 people viewed this question
Top Solar Pool & Spa Experts
Jay Finke
Jay Finke
Are you a Solar Pool and Spa Expert? Answer questions, earn points and help others
