Question about KitchenAid KCMS1555RSS Stainless Steel Microwave Oven
R-9h81 sharp microwave oven
The touch pad numbers stopped working. Right now only the minute cook
button is working.
What is the solution to this problem? What kind of parts it needs and will be able to put it my self?"
Thanks Barti
  • 1 more comment
  • barthi Jul 28, 2008
    It was nice of you to give feed back for the problem.
    Thanks a lot
  • aerobracero Jul 28, 2008
    Exact same symptoms except after using the minute cook button several times the problem goes away. Have no idea what to do. Thanks in advance.
  • urmnymkr Apr 09, 2009
    I replaced the fuse and now the led's on the display blink on and off but the key pad does not work.
    Help!
    Sincerely,
    Mike
Thank you.
Aerobracero
Posted on Aug 16, 2008
  • KitchenAid Master
  • 9,098 Answers
Replacement keypads for the R-9H-series of microwave ovens are no longer available.
So for as long as you can get by with the oven like it is, go ahead, but the only solution id to replace it with a new model.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online for current equivalent models.
Sorry I can't bring better news.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 13, 2008
Microwave is in Lock -- how do I unlock it?
" 1. CHILD LOCK
The Child Lock prevents unwanted oven operation
such as by small children. The oven can be set so
that the control panel is deactivated or locked. To
set, touch Custom Help, the number 1 and Start/
Touch On. Should a pad be touched, LOCK .
.. ON will appear in the display.
To cancel, touch Custom Help and Stop/Clear. "
Also, to find manuals........
Oct 03, 2014 | Sharp R-1480 Microwave Oven
How do I fix the programmed buttons 1 - 5, they stopped working? We can only use the 6 and above numbers.
You must dismantle the circuit board and check if some grease vapours between touch buttons and the the circuit film. Clean with some wet soft cloth.
Nov 13, 2017 | Whirlpool MH3184XP Microwave Oven
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Sharp Microwave on "Lock" and
The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
Mar 08, 2011 | Microwave Ovens
Works fine, except the beeps suddenly went silent. Examples: 1. When food is finished cooking, no beep any longer. 2. When pressing any key to set for cooking, no beeps any longer. Never thought that...
On page 21 of the owner's manual (online here), that's covered under "AUDIBLE SIGNAL ELIMINATION":
If you wish to have the oven operate with no audible signals, touch CUSTOM HELP, the number 2 and STOP/CLEAR.
To cancel and restore the audible signal, touch CUSTOM HELP, the number 2 and START/MINUTE PLUS.
Feb 16, 2011 | Sharp R-1520LW 1000 Watts Microwave Oven
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Tricky touch pad on Sharp R530 es microwave oven
There are two options here:
1. Order a new control panel frame which has the keypad, trim piece and door button already installed and swap your control boards into it.
The original part number FPNLCB346MRK0 has been replaced by part # FPNLCB346MRK0B and it runs $58.28 plus shipping.
2. Disassemble your control panel frame, peel off the old keypad and stick a new one on.
Even though the keypad alone runs only $35.66, this job takes a lot of time and labor.
If you (or someone you know) might want to replace just the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
Whichever option you choose, we have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
Jan 18, 2009 | Sharp R-530ES Microwave Oven
Unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Jan 06, 2009 | Sharp R-308J Microwave Oven
I'm sorry, but the keypads for for Sharp R-9H-type models are no longer available.
Please don't kill the messenger, but unfortunately, once the oven becomes unusable it will have to be retired.
Sep 06, 2008 | Sharp R-930AK Convection/Microwave Oven
KitchenAid KCMS1555RSS Stainless Steel Microwave Oven Logo
201 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
