Question about Kenmore 63942 Dryer
Model 110 72712101 kenmore gas dryer will come on run about 2to3 minutes then goes off after a short the glow will come on again but will not relight.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Here is a link to the parts you need.
Posted on Jan 02, 2011
Intermittant heating.It will begin to glow....sometimes the flames shoot out for a short time....but then go out. Then, it will continue to glow red without flames igniting,then goes dim....couple minutes...
This is usually caused by faulty coils on the heat valve. they can be purchased seperate from the gas valve and are relatively easy to install..
Oct 27, 2010 | Dryers
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
I have a gas Kenmore Dryer 74202200 and it heats sometimes, moreso when it first comes on. The glow plug works and it clicks and it fires up, but then the fire shuts off and the glow plug comes back on a...
if it runs for the first 15 to 30 minutes and then no heat you have bad gas coils,located on top of the gas valve,when the coils heat up they fail,if you try to start it again after it sits for a long time it will lite again,also you could have a bad gas valve,try tapping the valve to see if it lites,if it does lite while you're tapping on it most likely it will be the valve,let me know what you find and send the model number.good luck
Jul 26, 2010 | Kenmore 63942 Dryer
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
Dryer gas ignites Runs for up to 5 minutes flame goes out
check the igniter to make sure it is glowing white and not orange. if it's orange replace it. you may also need the gas coils replaced.
Oct 16, 2009 | Hotpoint Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 70 gas dryer will heat for 7 minutes then nothing
Change these:3d37aa7.jpgthey get hot and quit, then cool off and work some more.
Dec 31, 2008 | Kenmore 73952 Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Kenmore gas dryer model # 87566100
BAD SOLENIODS OR THERMAL SAFETY
Jan 29, 2008 | Kenmore 73952 Gas Dryer
Kenmore 63942 Dryer Logo
147 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
