Hi, I changed the cartridge both B and C but still getting an error of C. I replaced it a few times but still my printer doesn't work. Thx,
    Problem Solver:
  • 14 Answers
Maybe your cartridge carrier is defective. try to replace it... be careful to replacing the cartridge carrier
Posted on Jan 02, 2011
Brother mfc 5540cnz wont recognize ink
To rectify this error with your printer,
first of all, you need to snap the cartridge in and out a few times.
If this doesn't work, you need to remove the printer cartridge from the printer and then clean off the foil contacts.
You need to be careful while doing this and do not wipe the nozzles from where the ink comes out.
Insert the cartridge and switch on the printer. Now your problem might be fixed.
Get more information to fix cartridge not recognized problem .
Hope this information helps you.
Jul 28, 2011 | Office Equipment & Supplies
I just changed all the cartridges in my epson stylus sx12 but still says theyre empty
p { margin-bottom: 0.21cm; }
According to your problem first make sure that you have installed the cartridges properly. Go the the printer properties in control panel and follow the steps open the printinging preferences tab> maintainance tab > Ink cartridge replacement> then the window will show the process of the replacement of ink cartridge. Follow those steps of replacement. Then let the cartridge be processed, it will take a few time. And then your cartridge replacement will be finished. Then align the cartridges from the alignment option in printing preferences as well. If it doesn't solve your problem then the cartridges are faulty, replace a new set of cartridge is recomended.
Jun 09, 2011 | Epson Stylus C88 InkJet Photo Printer
I replaced ink cartrages. magenta cartage is not recognised by printer.it says put ink cart slowley but it says cannot print
To rectify this error with your printer, first of all, you need to snap the cartridge in and out a few times. If this doesn't work, you need to remove the printer cartridge from the printer and then clean off the foil contacts.
You need to be careful while doing this and do not wipe the nozzles from where the ink comes out. Insert the cartridge and switch on the printer. Now your problem might be fixed. If this does not work, it is better to inform the manufacturer or contact online technical support experts.
May 06, 2011 | Brother MFC255CW All-in-One InkJet Printer
Canon ink is not being recognized by printer
To rectify cartridge not recognized error with your printer, first of all, you need to snap the cartridge in and out a few times. If
May 05, 2011 | Canon Office Equipment & Supplies
Cartridge is not recognized
Try it a few more times, if that doesn't work, you'll have to get a new cartridge. (I believe your cartridge comes with a new head, it's actually the printing head that you need)
Canon cartridges are infamous for failing for no apparent reason.
Aug 26, 2009 | Canon PIXMA iP1300 Printer
HP Officejet 6310 All-in-One ''Cartridge Error: Cartridge on ...''
Hi for solution do this
First put out of the printer the Ink Cartriges then
press 4 + # + OK this send you a info menu
with the nav. Keys go to CHECKSUM FOR RELOCK DATA IMPUT press Ok 5 times . Then Go out there by pressing Cancell Button ant there you go if this dosnt work at the 1rs time you need 2 o 3 times more to ensure relock data ok
bye :)
Nov 14, 2008 | HP Officejet 6310 All-In-One InkJet...
Dell 926 printer
Dell cartridge are quite expensive, and refilled and non original cartridge are often not accepted by Dell printer. If you use non original cartridge often you keep getting this message unless you replace both cartridges.
Be also careful also if you use refilled, sometimes refilled can leak all over the inside of your Dell printer right when ink is coming to the end.
In your case try replacing both cartriges at the time, this usually clears the error.
A suggestion: Dell small inkjets are sold at a price often inferior to the cartridge set price, and now you know why, ask the price for a new Lexmark, HP, Epson,Brother, Canon etc. next time you have to replace a cartridge set, it may be worth buying a new printer.
Apart small inkjet sector, Dell produces excellent laser printers, computers, laptops and more.
You can read more opinions on small dell inkjets here or using google.
Aug 18, 2008 | Office Equipment & Supplies
E5 Error when I reinstalled new & original cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
597
Jul 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
BRother printer error code 41
The printhead is defective. Call brother hotline. Because this is a very common error (due to malconstruction on the mfc 3820 ) they might replace it for free. And when asked: OF COURSE YOU HAD ALWAYS RUN THE UNIT BY ORIGINAL INK CARTRIDGES!!!! :-) (take the ink carts out before sending or giving it to a service dealer!)
Oct 14, 2007 | Brother MFC 3820CN All-In-One InkJet...
15 people viewed this question
jasbo
jasbo
