Question about Samsung CLP 300 Laser Printer
How do you connect via bluetooth, from IPAD to my printer?
  • 26 Answers
You don't. The iPhone cannot connect to a printer via bluetooth. Has to be Wifi.
Posted on Apr 07, 2011
2 Suggested Answers
  • 18 Answers
SOURCE: I can't connect to my HP Deskjet 460 via
Is your Deskjet still in the default "Private" mode? If so, change it to the "Public" mode.
In the toolbox, go to the printer services tab and choose configure Bluetooth settings. Change the mode to public mode.
Go to --> http:/h10025.www1.hp.com/ewfrf/wc/document?docname=c00625408&cc=us&lc=en&dlc=en&product=466208
Posted on Feb 09, 2010
Since the iOS 9.1 update, my iPhone 5 has lost all Bluetooth connections and I cannot make them reconnect?
  • Turn off Bluetooth and restart your iPhone or iPad.
  • Repair the Device you Connect: Go to Settings > Bluetooth > Choose the device you are having issues with > Tap on the info button next to the device > Tapon Forget This Device.
  • Reset Network Settings: Settings > General > Reset > Reset Network Settings. You need to set up your Wi-Fi connections again after doing this.
  • Try restoring your iPhone: You can restore your device from iTunes or iCloud. Bear in mind that it will erase your existed data so you'd better back up your iPhone or iPad in advance.
You can check this article to learn more about how to fix iOS 9 problems
The Most Common iOS 9 iOS 9 1 Update Problems and Solutions
Nov 27, 2015 | Apple iPhone Smartphone
Pair to iPad
Till now I did not know you could pair a mouse to an iPad. When someone is selling mice you can connect via bluetooth, they will give you the manual to. I hope you know, the iPad is not a computer on which you can connect lots of things. Only when Apple allows you to put anything on, or connect via bluetooth, it can work. Not when you think it should be great.
Because Apple made it possible to connect their key board to the iPad, you now can buy third party keyboards that work with the iPad.
Jan 30, 2015 | Ckeyin Mini Optical Bluetooth 3.0 Wireless...
Using the keyboard for iPad not typing on the screen
check the manual...!
depends on the model - but it works with bluetooth- see a sample :
put the iPad in the slot built into the keyboard, and pair it with your iPad via Bluetooth
On your iPad, tap the Settings icon and then tap Bluetooth. Make sure Bluetooth is On.
Connect the Logitech Ultrathin Keyboard Cover i5 Logitech Support Article using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-0.jpg using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Sep 15, 2014 | Apple iPad Tablets & eReaders
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
Connect ip7200 to ipad
Via wifi or Bluetooth or 3G common
Dec 16, 2013 | Canon Tablets & eReaders
How do I connect my iPad with another iPad via Bluetooth
You have to have the 2 iPads basically side by side. Then you go to the bluetooth section on both. Then on each one it will come up with the name of the other iPad. The beside the name on each one it will say "not paired". Click the name on both iPads. Then it will pop up asking if you want to pair with the other iPad. Hope that helped.
Sep 06, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Ipad and Samsung Bluetooth pairing problems
I have had the same problem it's doing my head in so frustrating they will pair up but can't see each other even if right near have you found a solution?
Nov 16, 2012 | Samsung Galaxy S GTI9000 Smartphone
How do i connect my ipad via bluetooth to my bmw x5
Make your device discoverable or your truck Bluetooth discoverable select device then connect
Apr 07, 2012 | Apple iPad 64 GB 3G Tablet PC
I can't connect my iPhone and iPad via blutooth
iPad and iPhone have some limitations regarding bluetooth connectivity. I believe you will need an external application depending what do you want to do.
Mar 05, 2011 | Apple Computers & Internet
Sony erricson k800 cant recieve files via bluetooth although i can send via bluetooth.
Did you turn the bluetooth on and put the phone in discovery mode before attempting to receive something via bluetooth?
May 01, 2008 | Cell Phones
Samsung CLP 300 Laser Printer Logo
365 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
