Question about Toshiba Televison & Video
My Toshiba LCD TV, model no. 40RV52U, takes a long time to change channels. I've noticed this is the case with all LCD TVs in general but lately I've visited friends with LCD TVs that have a much faster response time. Is this normal?
SOURCE: lcd hdtv screen freezing
Im taking mine out back and putting about 6 rounds from my .45 in it and buying a real TV!
Posted on Oct 25, 2007
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
  • 159 Answers
SOURCE: Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Posted on Apr 24, 2009
  • 668 Answers
SOURCE: Toshiba LCD TV AV500E Turns off then on every 5 minutes
It sounds to me that the Main board is causing the problem. But I would get in touch with Toshiba for a warranty repair. It has a one year parts and labor warranty. It makes it a lot cheaper for the pocket.
Good Luck,
Skyassoc
Posted on Jun 20, 2009
  • 308 Answers
SOURCE: I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Posted on Mar 26, 2010
Toshiba 40RV52U TV has just started cycling off & on. Is this a problem with the power board?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 20, 2016 | Toshiba 40RV52U TV
Why does the screen go black with a screeching sound?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name and type of your device, in the search box [at the top right] of the display window; to gather down all the posts related to your device brand. It will make surf easy.
Jun 27, 2015 | Toshiba 40RV52U TV
Vizio LCD 47" switching channels takes very long
Has it always done this since you purchased it? Check the response time online for that TV, it may just be that it is a model with poor response time when changing channels. I've seen some value brand TVs that seem to take a full second or more to switch and go blue/black in between while switching.
Very painful to channel surf like that, so if you have a cable box etc hooked up use that for surfing channels instead if you can't handle the wait.
Oct 19, 2012 | Televison & Video
There's 4 horizontal white tiny lines appear on screen to make the picture become 4 equal parts from top to bottom with many horizontal lines. My TV is Toshiba Lcd(40RV52U)
You have failure/weakening in the vertical section , the retrace lines appear due to the change in the freq.
Check out small value capacitors in this section. confirm by shorting parallel with the right polarity. Unless you are familiar with electronics please do not attempt unless with help. the fault is not very serious and could be attended with low expense.
Jun 30, 2010 | Televison & Video
My toshiba problem.
You may have bad T-CON board, try cooling it with small fan blowing on the vents of the TV.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 30, 2010 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 40rv525r LCD t.v. have sound but turned
Sorry, I donʻt have solution, but I do have this exact same problem, same model of TV! Iʻm wondering if youʻve had it fixed yet and if so, how did you do it?
Apr 20, 2010 | Toshiba 40RV525R 40 in. HDTV
Vizio 32/DirecTV - slow to change channels
Some TVs switch faster than others, plain and simple. I went from a Sony LED to a Sanyo LCD TV and there's a world of difference between the two in terms of how quickly each powers on and how fast one channel goes to the next after inputting the channel number on the respective remotes. The Sony is lightening fast compared to the Sanyo. I have a Phillips LCD in a bedroom that takes a long time as well, like the Sanyo. Personally I think you get speed with either the LED (over the LCD) and/or it's related to the quality and associated price you've paid.
Dec 09, 2009 | Vizio L32 32 in. LCD HDTV
Apr 24, 2009 | Toshiba 40RV525U 40 in. LCD TV
Televison & Video Logo
112 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
