Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
596.76523500 Kenmore Elite Trio . Freezer works fine. Refrigerator is hot. Damper control is open, no cold air coming through. Help, and Happy New Year!
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
SOURCE: Kenmore Elite Trio 596 73503200
Did you ever get the problem fixed with the compressor noise
Posted on Jul 09, 2008
  • 1122 Answers
SOURCE: kenmore elite trio bottom freezer refridgerater 795 7555
there are 3 ways it can be held on,screws,snaps,clips or slides one way up or down or side to side,to make sure what you have get the model number from inside the frig. ,go to sears .com click on parts put in your model number and your whole frig diagram will come up and you will see exactly how it comes apart,let me know how you do-mike
Posted on Oct 01, 2008
  • 66 Answers
SOURCE: refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Posted on Nov 16, 2008
SOURCE: Kenmore Trio Freezer section makes snow in freezer compartment.
no its not a compressor problem. it not going into a defrost.
Posted on Jan 22, 2009
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Kenmore elite trio 596 73503201
This happened on my side-by-side. There is a damper at the inside top of the refrigerator compartment that was failing to open to allow cold air in. I took the cover off and propped open the damper while I ordered the part and waited for it to arrive. Problem solved and hope to keep it running another few years.
Nov 13, 2013 | Kenmore Refrigerators
Kenmore model 596 72913200 freezer works but fridge not getting cold
This will be an air flow problem from the damper failing. Usually what happens is, the air vent is not allowing air to pass at the damper due to the motor not opening and allowing the cold air to pass into the refrigerator side. A good way to check it is, to feel the amount of air coming out of the vent between the freezer and the refrigerator. If the air flow seems slow, or no air at all, replace the damper to restore air flow to the refrigerator.Here is the part you need to order.
The part comes with a 365 day, any part, any reason return policy.
Regards,
Richard Roth
http://appliancecafe.com
Nov 12, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer still working. Refrigerator not cooling. Hot to top on inside of left hand door as you face refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Kenmore Elite Trio 7855 (25 cu. ft.)...
Kenmore Elite 79577559600 refridgerator warm, seems to be not working but freezer working fine.
the damper-vent door between the refrigerator and freezer is probably frozen shut therefore not letting the cold air from the freezer enter the refrigerator,deice it with a hand held hair dryer,then check if its controlled by a motor or manually and see if these could be your problem
Jan 01, 2011 | Refrigerators
I have a Kenmore refrigerator/freezer model # 596.65232401, this is the one with the freezer on the bottom and refrigerator on top. The freezer works fine, the refrigerator was not cooling, I removed the...
What you didnt state was whether you had cold air blowing when the damper opened up. If you did, then the problem will be with the damper assembly itself, or the control board, which is what you would adjust to change temperatures. This microswitch you mentioned, was this on the control board? then the control board is the problem. If you did something with the damper assembly, then that might be the problem.
If you dont have any cold air blowing when you opened the damper door, then airflow is your issue, and you will have to include more symptoms for a refrigerator repair diagnosis.
Nov 27, 2010 | Kenmore Refrigerators
My kenmore elite refrigerator (trio) model # (p) 75523 serial# (s) 10477898ev the refrigerato is not cold anymore, but the freezer is working fine. the compressor is hot, and the fan is working. ...
I am pretty sure that two companies made the Trio for Sears and I will help you. At this point I believe you are having a defrost or damper control problem. Would you look around the frame or freezer drawer and see if there is a different number than p75523 because Sears uses that number for another reason than the true model number. You may find a Maytag number or an LG number on your model. Sears places numbers like this for example 323.26589 as a model number. I am ready when you are. Sea breeze
Dec 12, 2009 | Refrigerators
THE FREEZER IS WORKING BUT NO COLD AIR IE GOING INTO THE REG. The fan on the back of the unit is working. It has been in the garage so it is not froze up. Any ideas. It is a Kenmore Elite Trio
The problem is that the damper isn't working properly. It is supposed to open and close to send cold air from the freezer to the fridge. Open the door to the fridge, and look for the vent, close the door switch, and see if you can feel cold air coming out of the vent.
Either the motor that controls the damper is broken (most common) or the control board that sends power to the door to open and close as necessary is not sending power.
Jul 27, 2009 | Kenmore Refrigerators
Fridge is hot, freezer is working properly
The temp control damper solenoid is frozen closed - or the solenoid itself is failed.
CLICK HERE
for the part
#13 in THIS DIAGRAM
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
241 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
