Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Have spark. have fuel. No start. was running well with intermittent choke use to correct bogging. wassup? I.m confused.
  • 784 Answers
There is a chance that your computer needs to be ' Re-Flashed ',, this is now the most common problem with the Polaris snowmobiles -- they just can't seem to get this all right. I have the 900RMK ( the first one ) and after going round and round with Polaris ( in and out of the shop over 20 times ) it is now running good. lots of times the dealer will re-flash the unit with no charge to you and it only takes a few minutes.
sorry to hear that you are having troubles with your Polaris --- I work and live out in the middle of nowhere Alaska and I see many sleds come through here and it is always a Polaris sled that brakes down out here and needs to be towed out ( with a very sad rider steering it )..and after all my trouble that I had with mine and lack of help from Polaris I will never buy Polaris ever again. but stop by the dealer and get the re-flash,, it will work great after that,, ( until the next problem :-) ).
Happy NewYear !!
c...
Posted on Jan 02, 2011
  • stevevulcan Jan 02, 2011
    sorry, not helpful. re; 1995, 500cc indy classic. no computor. Lotsa miles and years of good service. Could the crankcase be loaded up with fuel because the clutch is dragging at low rpm?
  • chris wheeler
    chris wheeler Jan 02, 2011
    so sorry, I did not know the year of your sled.
    as far as the clutch dragging at low rpms -- this is sometimes caused by bad springs in the clutch or wrong belt size.
    and the fuel in the crankcase idea --- I am not to sure what you mean by that,, can you please clarify this thought.
    you might remove and clean the carburetor -- sometimes water and debris will sit in the bottom of the bowl and this can lead to a fowled up jet which will not give you the proper air fuel mix and might be one of the reasons you are having to play with the choke(?). I have also found that after years and years of use that the throttle slide gets pitted where the idle screw rests ( look at the slide and see if in fact this could be part of the problem,, and I have found that if you smooth this pit out and re-adjust the idle screw that this should give you a better and smoother idle.
    please let me know what you find out - as I work on snowmobiles 9 months out of the year here in Alaska and if I can learn something new I might be able to use it in my work.
    again, sorry for the mis-communication on make,year and model.
    have a great night,
    c....
Hi my yamaha 25 6L2 outboard runs with choke on but when i go to put my choke in the engine will run for about 10 secounds then start bogging out it sound to me that the was no fuel getting to the car
are the fuel pump diaphrams hard ? valves sealing in the pump ? try priming the fuel while its running and see if stays running ! compressions over 100psi ?
Aug 14, 2014 | Motorcycles
Snow blower losing power
Start with fuel. Unhook fuel line from carb. and see if fuel runs out.
Jan 03, 2014 | Garden
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
2003 yz 250 starts and idles but runs rich and bogs as soon as the throttle is applied
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent or overflow.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
11. The enrichner valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2002 yz250 idles fine but bogs and tries to die when twisting the throttle...
Bike dies when you give it throttle
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 19, 2012 | 2003 Yamaha YZ 250
Xr400r's been stood a while, had trouble starting it, changed the plug, now starts easier but bogs on use of the throttle and only runs with the choke on half, changed the fuel cleaned the main jet but...
Make sure the carb is thoroughly cleaned, all jets not just main. The half choke is compensating for the slow circuit jet. Check your air/fuel mixture. Also, check the air and fuel filter. If all checks out fine and you still encounter the problem, could be : bad gas, wrong spark plug heat range, or most likely the diaphragm for the top of the carb.
Aug 12, 2011 | Honda XR 400R Motorcycles
Poulan 16" saw, start fine,
Usually when a small engine starts fine.. runs fine.. gets hot it's ignition related.
First you want to make sure the cooling fins are clean.. remove any covers and clean the area around the head. If those fins are clogged.. not good.
Second I would check the spark.. and the spark plug condtion.
Also for power tools that don't get used that often.. fuel sytems get gummed up.. fuel gets old.. and folks tend to use the fuel in the can they mixed two seasons ago. Make sure the fuel mix is correct.
I assume it is running fine with the choke off.. however check the choke for proper operation.
Clean or replace the air filter as well.. once all the ignition and fuel components are in good order.. only then should you begin to adjust the carb. Probably not needed.. but don't do it until you are satisfied that you have good air fuel mix and proper spark.
Best of luck
Apr 08, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
2001 V star 650.. Bogs out then corrects itself
If the bike runs better with the choke on a quarter or more of it's range when you're riding it can mean that your motorcycle's engine isn't getting enough fuel into the engine to run normally. Meaning you are running too little fuel into the engine. This can show up as a dead white spark plug with glassy bubble deposits around the electrode.
Possible reasons for this condition;
a. The fuel filter.
b. Most likely the motorcycle hasn't been run enough, this allows the fuel to evaporate in the carburetor and plug the jets that regulate the fuel/air mixture.
Aug 17, 2009 | 2001 Yamaha V Star 1100 Classic
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
324 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
