Question about GE Monogram ZISS480NRSS 48" Built-In Side-By-Side Refrigerator (ZIS-S480NRSS, ZIS S480NRSS)
It seems that the water flow out of the dispenser is very weak. It takes a while to fill even an 8oz glass. The unit is 8 months old and has been this was since the beginning. The filter has never been changed.
  • 29 Answers
Try taking the line loose from the back and take a can of compressed air and spray through the line to make sure nothing is clogging the line or make sure the line is not crimped.
Posted on Jan 02, 2011
Just installed a new Bosch fridge, ice dispenser dispenses ice but water does not dispense?
Make sure it has water on the container and no obstruction on the water dispenser. Try several times. Since it was new unit, sometimes water has not yet completely fill the dispenser tubing hence it will not dispense water.
Look for some carton, foam or plastic obstruction around the dispenser, it may cause hindrance of not flowing water from dispenser into the glass.
Thanks for asking.
Jul 03, 2011 | Bosch Refrigerators
Gwl227hsya, water not dispensing. Water in the bottle inside the fridge. Can hear the pump but no water coming out. Fridge is only 6 months old!
Any luck with fixing this- I have the same problem with this fridge- six months old also. Not even filling up ice dispenser either~?
Feb 20, 2011 | LG Refrigerators
My new (2 months) Samsung refrigerator barely dispenses water. It just trickles out. It would take 5 mins to fill a 20 oz glass. The ice works fine (good water flow to it). The water filter is fine....
The only thing between the inlet line and the spout?
Water Inlet solenoid, a valve that lets water in. Follow the inlet line to the back of frige. Unplug and turn off water before service. repace valve. EZ FIX...
Mar 29, 2010 | Samsung RS2534 Side by Side Refrigerator
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
Water dispenses very slowly on Fridge
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The coil of tubing is normal so you can move the fridge out from the wall without damaging anything.
Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 14, 2010 | Refrigerators
How to increase the water flow from water dispencer on a FLSC238DSO when getting water it takes for ever to fill a glass
If your fridge has a water filter, you should change it every 3 months. An old filter can cause slow flow problems.
But it will never come out as fast as the kitchen sink. Depending on the location of your fridge, you have 10 to 25 feet of 1/4" pipe between your water glass and the high-flow plumbing, and water just won't move very fast through that.
Sep 16, 2009 | Refrigerators
Low water pressure on door dispenser
i have a similar problem. my water dispenser worked perfectly with the origional filter for about 8 month . then there was a decrease in water output. i then changed the filter.this worked fine for about 2 weeks . changed the filter again 2 days of water output. i have since changed the filter 2 more time with the same results. i do not have a kinked line . i have had the refer for about 1 1/2 years. ice production is down also . any thoughts?
Jul 01, 2009 | LG LFX25960ST Stainless Steel French Door...
Water Dispenser
does your refrig have a built in water filter? it may need replacing. if thats ok try checking your water supply to be sure that there isnt a kinked water line. if both of those check ok you may have a bad fill valve.
Dec 11, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Water takes a while to start
put a 8oz glass upto the dispenser and start filling when the water starts the glass should be half full in 6 seconds if not the water pressure is to low if so you have a small leak some where in your tubing these are press and pull fittings usually and are located by following the line from under the door up under the ref.and back to the water inlet valve on the left rear of the machine hope this helps and good luck. oh if you have the type water valve that is up on the water line to your home make sure it is not on a plastic pipe because plastic piping will make a flap and restrict your flow
Dec 06, 2007 | Amana ASD2326HE Side by Side Refrigerator
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
