Question about Maytag Refrigerators
The icemaker is not making ice regularly. - Maytag Refrigerators
  • Mark Carey Jan 02, 2011
    When is it making or not making ice?
  • 6,993 Answers
read my tips on how to fix an ice maker not making ice problem;
http://www.fixya.com/support/r7602816-steps_when_ice_maker_not_making_ice
I hope it helps.
Posted on Jan 02, 2011
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    How do I get the icemaker to make ice
    TROUBLESHOOTING ICE MAKERS.
    Nov 23, 2014 | Refrigerators
    Icemaker not making ice
    sometimes when the icemaker is not used,,water will thaw, drip/pool around the auger,,this will keep it from dispensing.
    take the bin out, inspect all the parts for ice...ck that the on/off wire is in the correct position
    Apr 15, 2014 | Kitchen Appliances - Others
    Ice cube tray won't stop making ice.
    This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
    Thank you
    Rick
    Mar 12, 2012 | Refrigerators
    Used to make several batches of ice a day, now 1-2 a week.
    If your refrig has the icebucket on the door and the icemaker on the roof of the fridge then you have two eyes on each side of the freezer....they are bad. If not then the icemaker module is bad. If you have a regular icemaker that hangs from the left side of the freezer then the module is bad. Also......Is your freezer still working good? Icemakers will not work if the temp is not low enough. Are you sure the icemaker is cycling but not making the full number of cubes? Low water pressure will force the icemaker to make only a few cubes at a time
    Sep 11, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
    Ice maker wont make ice
    Put about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water inlet valve . If the ice stays in the icemaker , replace the icemaker . Also , make sure the fill tube to icemaker is clear of ice and the coils under refrig are clean of dust , lint , etc..
    Aug 12, 2009 | Roper Refrigerators
    Will the refrigerator work if the ice machine is not hooked up?
    You need to have the icemaker assembly in the unit. Now unless you are talking a clrco2075 you have to hookup the water. If its a regular icemaker then by lifting the arm everything should work. The icemaker has sensors in it and thats why you need the icemaker in place. What model do you have? Just to be sure, some models you have to program the icemaker to stay off.
    Jul 16, 2009 | U-Line Refrigerator Ice Maker
    WILL NOT MAKE ICE
    1. Turn the water on with the valve in the back of the refrigerator.
    2. Make sure the filter is not clogged.
    3. If it has made ice regularly and all of a sudden stopped you may have a waterling frozen goibg to the ice maker.
    4. Other problems make be a bad solonoid valve and no wate ris sent to the icemaker.
    Jul 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Kenmore - Ice Maker Not making much ice
    check water inlet valve on your frig
    Nov 06, 2007 | Refrigerators
    Ge monogram zd115c automatic icemaker not making ice
    Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
    Dan
    Nov 04, 2007 | GE Monogram ZDI15C Automatic Icemaker
    Refrigerators Logo
    104 people viewed this question
    Top Maytag Refrigerators Experts
    Bailey's...
    Bailey's...
    Shehu Pro
    Shehu Pro
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
