Question about Delta Plumbing
Can't keep single hole faucet from coming loose
    Genius:
  • 1,015 Answers
One method that I have had good results with is to shut off water supply to faucet and remove supply lines then remove faucet from sink. Clean surface of sink and faucet base and dry completely. Get a roll of double sided carpet tape andput a couple of layers on sink covering slightly larger area then faucet base.use rubber or plastic gasket that came with your faucet and put another ptece of tape on bottom side.Put your faucet back in and tighten retaining nut as tight as you can. You can trim excess tape from around faucet base with exacto or utility knife. Hope this helps you. Have a good new year and thank you.
Posted on Jan 02, 2011
Bathtub faucet leaking a lot
Change the gaskets.
Popular Grohe 3427 Concetto... Repair Questions - Fixya
www.fixya.com/support/p1162411-grohe_3427_concetto.../popular
Popular Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair ...
Grohe 3427 Concetto Single Hole Bathroom Faucet ... - Fixya
www.fixya.com/search/...grohe_3427_concetto.../grohe_faucet_leaks
Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome, grohe faucet leaks related issues. Get free help, solutions & advice from top Grohe experts
Nov 04, 2015 | Grohe 3427 Concetto Single Hole Bathroom...
I need anInstallation Manual for Grohe Concetto faucet..where can I find one?
contact the plumber and have him fix his mistake the faucet came with instructions . what did he do with them
Oct 16, 2014 | Grohe 3427 Concetto Single Hole Bathroom...
We have a Grohe faucet similar to the Concetto. It single hole mount. Recently, it became loose and no matter how much I've tried to tighten it with a rod/nut/washer underneath, it will not tighten. ...
looks like you'll have to remove it and examine it. Brass is a soft metal, I hope you've not stripped out the threads, Grohe is an expensive faucet. i fall else fails and the hreads are stripped out, I might try a tough adhesive caulk like a 3M 5200 marine grade. Apply liberally from the bottom. let it set firmly. Perhaps tape a piece of cardboard over the hole in the countertop from the bottom. this would keep the caulking from falling out before it sets. unconventional, but something to try before buying another $200 faucet. what have you to loose?
Oct 13, 2010 | Grohe 3427 Concetto Single Hole Bathroom...
I have a Moen single lever faucet. There is low water pressure coming from the faucet, Can anything inside the faucet be replaced to increase the water pressure? Thanks Bob Fruhling
I have had the cartridge replaced in my moen single handle faucet with sprayer in the end and now it turns off by itself. Any suggestions on the problem
Aug 15, 2010 | Moen 7437 Chateau Single Hole Kitchen...
The base keeps coming boose. i keep tightening and
If you just need to keep the nut from coming loose, try LocTite Blue (assuming metal thread and nut). You should be able to buy it at the local hardware store.
I had the same problem with a slightly different Price Pfister model sink. My problem was primarily because the sink basin was thin and not "beefy" enough to support the faucet. The whole thing would flex because the metal was thin and the nut would come loose.
Using wood for reinforcement down there is a bad idea (it would get wet and rot). So, plastic was the way to go.
I bought an inexpensive piece of plexiglass/lexan at the local home improvement store. A cheap plastic cutting board would work well too.
I cut a rectangle that was a couple inches wider than the the faucet holes and that would fit underneath the sink basin where the holes for the faucet were.
I marked the holes and cut them with a hole saw (Go slow, the heat from the hole saw will melt the plexi!). Cutting slightly oversize makes everything fit easier.
I put my new "reinforcing washer" in place and tightened everything down. The nut snugs up nicely against the plastic and after four months: no more flex, no more nut loosening.
Jun 13, 2010 | Price Pfister Marielle Kitchen Faucet with...
How to insert bearing washer on moen single handle kitchen faucet
I have the exact same problem! The gray plastic washer has popped out from between the plate and the brass groove below the washer! I can't for the life of me get it back under there. Because it's sitting too high, the handle doesn't fit and the metal plate is loose.
Please help!
Apr 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
No water to single hole faucet after installation
the cartridge has trash in it.remove and clean,will work after that is done.
May 24, 2009 | Danze D222158 Parma Single Handle Hole...
Removal of single hole kithcen faucet.
There is a bracket that slides between the threaded shaft and the bottom of the sink. There is usually a nut which is tightened up against this bracket. When this nut is loosened, the bracket will slide out. Of course, you first have to unfasten the two water supply lines. Once the bracket is removed, the two water lines which are made into the faucet are gently bent and the whole thing is removed from the top of the sink. Hope this helps.
Mar 09, 2009 | American Standard - Lavatory Faucet -...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
209 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
