Question about Reddy Heater-170,000 BTU Kerosene Deluxe
I have the Reddy Heater as well. I took the top off and the igniter lights up. The heater will attempt to light and then shut down after 5 seconds. The error code says flame problem. Can you help?
  • 2,509 Answers
The thermocouple may be faulty, or the valve is seized. Check the thermocouple connections.
Posted on Jan 02, 2011
I have a 40,000 btu reddy heater multi fuel heater. the fan starts but there is no flame and it will shut down after only a few seconds
That's the safety; it's supposed to do that to keep you from getting blown up!
Did you follow these instructions?:
http://www.ehow.com/how_10008271_reddy-heater-instructions.html
Does the power light come on?
Does the igniter heat up for 5 seconds?
Jan 24, 2013 | Reddy Heating & Cooling
125btu reddy heater, somene mixed some gas in the heater and now it won't ignite. how to fix??
Drain it clean it out real good clean out the fuel system end to end. From the line in to the tank thru the filter and so on remove the nozzle clean the screen and nozzle put it all back together. with the top section removed try to start the heater. You should have a fine mist of fuel and spark if it lights shut it down and clean the photo electric eye with a soft cloth and windex. make sure the igniter is clean and close to the fuel mist for ignition, put the top on and turn on your heater.
Dec 14, 2010 | Reddy Heater RH125T Kerosene Forced Air...
My heater keeps shutting down. Just put fuel in. Lights and runs about 5 seconds
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 12, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
My ALL-PRO R60A heater light and burns for a
I think you are talking about the igniter,go on line,I think reddy heater parts,type that in.
Oct 17, 2009 | Reddy R60A Utility Heater
Reddy pro155 runs for 3 to 5 seconds
Reply with the correct model number. "Pro 155" designates a series. We need to know whether you have a heater with a spark plug or a heater with an ignitor (glowbar).
Feb 01, 2009 | Reddy R155D Utility Heater
Heater won't ignite
Moving mine while it was running fouled the spark plug. You can remove the top of the Reddy Heater and access the plug. In my case took less than 10 minutes and it's up and running again. I removed the top and replaced the spark plug. No problems
Jan 24, 2009 | Reddy Heating & Cooling
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
91 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
