SOURCE: DHCP List Script
iwconfig is the command you're looking for. You can find more at the manual pages for madwifi and the manual pages for iwconfig.
SOURCE: Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
SOURCE: Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
SOURCE: how to initially configure the access point
Should work right out of the box. Are you asking what type security you should set up?
There is password security, turn off the broadcast security, MAC address security and others.
May I suggest Network Magic to help you set up and maintain your network.
I use the paid pro version and love it.
Get it free - google Network Magic
SOURCE: Access point configuration
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default 192.168.1.1 according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point
http://www.tomsguide.com/us/asus-wl-wl330,review-233-3.html
http://support.asus.com/faq/asus-faq.aspx?no=E8D3A5FD-995C-D299-0AE3-FBF28AA04DA6&SLanguage=en-us
http://www.ddp.ru/upload/images/PDF/WL_HDD25.pdf
Hope this helps
