Question about LG WD-1280FHD Front Load Washer
I have a Kenmore elite washing machine. There appear a F20 code. What does it mean? If its trouble, how do I correct it? Thanks.
  • 1,557 Answers
Its a water fill fault press power cancel twice this should reset the computer
Posted on Jan 02, 2011
My Kenmore Elite HE 5t is showing the F20 code 15-20 seconds into the washing cycle. F20 standing for Water inlet problem. We have cleaned and checked all inlet ports and they are good so what else
Hello Shannon;
My name is Peter. I am a retired field service appliance technician.
Code F20 also stands for pressure switch.
You have a incomplete model number so I am not sure if this is the correct switch.
Substitution: W10514214 - $48.00
This is just inside the top cover, right hand corner.
The diagram is on the following link. Plug in your model number.
Water Filters Lawn Garden Appliance Parts
Dec 11, 2014 | Kenmore Elite HE5t Washer
Kenmore elite h5
Hello there and welcome to fixya
I am very sorry that you are having a troubles with your machine
I know that it can be very frustrating when dealing with error codes so i will do my best to try to help you thru this ok?
ok well first the f20 error code is a no water code meaning that the machine may not be getting any water into the machine or very little and after 6 minutes the error code will be shown on the display .
So what do u need to do is this
f you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Feb 10, 2012 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite HE3t and it has an F20 error code. What does this mean?
The F20 error code means; no water was detected entering washer or pressure switch trip was not detected after 6 minutes
Many times that is caused by a blockage a pinched fill hose,or the filter screen on back of washer where hoses attach to are clogged
Good luck,i hope this helps
Gene
Aug 01, 2011 | Kenmore Elite HE5t Washer
What does code F20 mean on Kenmore elite 45986
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first
Jun 06, 2010 | Kenmore Elite 45986 Front Load Washer
My washing machine has a trouble code showing,the code is "F20",what does this mean?
F20= flow meter, they sense the 'flow', if no flow after a certain amount of time it errs out, replace the sensor, it is erratic. Tell your tech he can replace it or get a 'recall'
Oct 23, 2009 | Kenmore Elite 45986 Front Load Washer
Code F20 is appearing on me washing machine
May 27, 2009 | Kenmore HE2 Plus Front Load Washer
Hi
Error F 20 means "No Water Detect" error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
You'll need to check for the following--
1- Check the Inlet water valve if it is clogged.
2- Make sure water taps are working fine.
3- Check inlet hoses for kinks or clogs.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 26, 2009 | Kenmore HE2 Plus Front Load Washer
F20 code.
in my fixing f 20 needs a new cpu main board in the top washer middle back side
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
2006 kenmore smartwash quietpak4 he3t F20 code washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE HE5
possible low watewr pressure or slow fill. Regards Engineer
Jul 22, 2007 | Kenmore Elite 45986 Front Load Washer
LG WD-1280FHD Front Load Washer Logo
138 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
