Question about Vacuums
How to set temperature readings in "C" on the main unit?
My dyson animal corless has a blinking red light and will not chareg. How do i fix this
Hello, this is Ava with Think Crucial.
There are possible reasons why your Dyson unit flashes a red light. If the red light flashes with the machine in the charger, the battery may be outside of its temperature range. Remove the battery from the charger and leave at room temperature until the red light no longer flashes when placed in the charger. Also, ensure that the filter is correctly positioned within the main body, with the metal sensor in the bottom left-hand corner facing the main body. If the problem still doesn't fix, I would suggest to get in touch with Dyson for more troubleshooting guide. Dyson number is 1-844-679-1647.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 21, 2016 | Dyson Vacuums
I have a 18 yr old Admiral DH359 demudifier. When I turn on the dial (switch) it gives a humming noise buy the blade does not rotate. After about a minute or two it shuts off because of condenser over...
The problem with your unit is the fan. The engine behind the blades have gotten spoilt hence its inability to roll the blades. Usually when the engine of a fan is spoilt as a result of the coil the engine still tries to move but due to the bad coil the engine hums but does not come to a start. The fan is meant to be the main component which regulates the temperature of the unit if the fan does not cool the unit then the unit will overheat and go off. Simplest solution is to extract the entire fan plus its engine and get ? replacement for it. If you have the required expertise to open and reassemble the unit you can do this yourself otherwise get an expert to carry it out for you. Hope this solution has been helpful?
Jun 23, 2011 | Vacuums
I have an Equity Weather Station model 31215B and i was wondering if the outside wireless thermometer is waterproof .
The wireless unit that transmits to the indoor unit is weather resistant, but not immersible. Even so, try to shield the transmitter from the sun and rain, if possible. When positioning the transmitter, keep in mind that direct sunlight may cause false readings and mounting it on heat-retaining materials (like brick) will show a higher temperature, even after sunset. Avoid mounting it anywhere near things that give off heat (air conditioner units, dark exterior walls, etc.).
LaCrosse has not yet uploaded the manual for this, but you may check later at:
equitybylacrosse.com/31215
Good luck from Detroit, MI.
Apr 29, 2011 | Vacuums
The vacuum seems to have lost a lot of suction power and it is only a month old. Seems like there is a clog or something, all filters are cleaned and after a vacuuming session, nothing is in the...
sounds like there is blockage in the suction hose -- lay the machine down and remove the lower floor plate and clean out the hose area where it bends down to the floor unit ( use a wire coat hanger to fish out the blockage ). also check the main hose for any obstructions.
c...
Feb 17, 2011 | Bissell Cleanview Helix Deluxe Bagless...
I've been very happy with my Pronto 2 in 1 until recently, when it doesn't seem to "****" very well. I've cleaned the filters, etc, and the motor sounds fine. Any suggestions?
Did you check the smaller filter inside the main filter? The main filter comes apart to reveal a smaller filter inside the main filter. This needs cleaning also. If you have found and cleaned that one also. Check the Hose at the bottom for restriction. Thats about it.
Jan 09, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I cant get my weber remote thermometer to read the temp.
Note: both the transmitter and receiver unit have a re-set button under the battery compartment lid. If the receiver is not receiving a signal from the transmitter, you will need to disconnect the probe and re-set both units while 'on' before re-connecting the probe.
This is straight off the weber website, and it works coz mine just started reading temp
Jan 08, 2011 | Vacuums
I have lost my manual for Nexxtech thermometer model6312030. I can't get it to read the outside temperature after I changed the batteries. How do I reset to make it read. Or better yet, how can I get a...
You must reset the outside unit every time you change a battery. To rest insert a paperclip into the small whole marked "reset". Temperatures should now appear on the inside or remote unit.
St. Bruno, Quebec
Nov 10, 2010 | Vacuums
No water or solution through main unit
It is definitely the heater which is clogged. The heater is contained in the handle. Symptoms are that tools will displense cleaning fluid but main cleaner jets will not. Only the main cleaner jets use fluid which has been heated. The heater is quite easy to dismantle and clean however you will be working near mains electricity so ensure the unit is switched off and unplugged
Jan 11, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Steam sparging line attached to downcomers on HRSG
The reason for this is to keep the HRSG warm to reduce fuel costs. Due to the price of Nat Gas, it is adventageous to supply sparging steam to keep the HRSG warm so that when the Comb Turbine is called upon to start the HRSG metal temperature will be greater than ambient temperature.
Jun 26, 2008 | Vapor 3000 Steam Vacuum
When squeezing trigger and Depressing Clean surge Button on Upper handle of the Hooover Steam Cleaner F5914-900 there is no "snap" indicating trigger rod is in place. Everything else went in as...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=552215
Generic problem for all Vacuums
Posted by lnikol6 on Apr 28, 2008
Hoover Steam Cleaner F5914-900
When squeezing trigger and Depressing Clean surge Button on Upper handle of the Hoover Steam Cleaner F5914-900 there is no & quot; snap& quot;
indicating trigger rod is in place. Everything else went in as instructed. The screws and bolts were no problem
this concerns me because the main complaint I read about this model was leaking from the trigger and clean surge and the problem was not getting the rod in place. No matter how many tries or people (three) it still doesn't occur.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I would suggest getting a schematic, owners manual or product breakdown to see what you are doing wrong or to check with the Hoover tech support line to see if the can either mail, fax or email the schematic to you so that you can complete your service job. There is something definitely happening with the serv job that we are overlooking and the schematic or product breakdown will help in the serv job you are doing, it sounds to me that you are doing things right but there could be another broken part or while installing the current part may not have been install properly, or is in need of an adjustment. Feel free to contact your local vac dealer or contact the Hoover Tech Line listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
Vacuums Logo
11 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
