Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
I added the Belkin Pin number to my computer instead of my grandparents by mistake and now they can't internet access on their computer but I still can. Help?
  • 335 Answers
If you try to connect their pc to the wireless you should be prompted to enter the pin number. enter it into their pc also, and it should work. If this doesn't help, please provide more details and I can help more.
Regards,
Joe
Posted on Jan 02, 2011
Where is the wps button on a N 1 Belkin route?
Using Wi-Fi Protected Setup
WPS uses WPA2 (described below) for encryption. It does not
provide additional security, but rather, standardizes the method for
securing your wireless network. You may use either the Push Button
Configuration (PBC) method or PIN method to allow a device access to your wireless network. Conceptually, the two methods work as follows:
PBC: Push and hold the WPS button located on the back of your
Router for three seconds. Then initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WPS. The client has now been securely added to your wireless network.
PIN: The client device has a PIN number (either four or eight digits)
that is associated with WPS. Enable WPS through the GUI shown
below. Enter the client's PIN into the Router's internal registrar
(accessed through this GUI). The client will be automatically enrolled
into your wireless network within two minutes.
Oct 04, 2014 | Belkin (F5D8231-4) Wireless Router...
Tip
What i have to do if its asking for a PIN Number when connecting a Belkin...
Hi Friends,
When you are connecting the Belkin router in Wireless,if it asks for PIN Number then please follow the below mentioned standard steps,
Step 1:Connect the belkin router to any one of your computer with an enternet cable.
Step 2:Open Internet Explorer and type 192.168.2.1 and click on Enter button in the keyboard.
Step 3:Now you will be able to see the belkin router page
Step 4:On your left side click on Wifi Protected Setup (WPS),now it will ask for password leave it blank and click on Submit.
Stpe 5:Now Change the WPS (Wifi Protected setup) to disable and click on Apply Changes.
Step 6:Now Try to connect the Wireless Networks in your wireless computer,it wont ask for PIN Number.
The above mentioned steps are the standard steps for the this problem.This is done because by default the belkin router's will be enabled with 2 security features so we have to disable any one of this feature.If you disable this then you wont have any Problem in the belkin router.
on Mar 16, 2010 | Computers & Internet
I set up wireless network for my boss, using Belkin wireless n router, so the 3 computers can connect to the same wireless printer, and she can access this network with her home laptop. All is well except...
If possible, to rule out the modem as the cause, connect a computer directly to the internet(bypassing the router entirely). If it is the router, you could try flashing it back to factory defaults and reconfigure. Log into the router's firewall feature and see if port 443 is blocked to the outside--this could cause https connections to fail.
Mar 04, 2011 | Belkin F5D8236-4 Router
I want to extend the antenna on my d-link router. Reason: My computer shop is metal building, wireless signal is weak. As long as I don't short extension cable is this ok?
Instead of removing the antenna from the router you can buy a cheap working second hand router in market (better buy a second hand belkin router, because belkin provides free lifetime phone support also free lifetime hardware support for certain routers whose model numbers starts with F5D or F6D....Dont buy any belkin routers with model number that starts with F7D)
Now configure the second router as an ACCESS POINT (you can call 18002235546 to get help to change to an access point)
run a long ethernet cable from dlink router to the second router (belkin)... you can place the belkin router anywhere where the cable can reach...
The belkin router will broadcast the signal and you will get better signal strength...
Feb 03, 2011 | D-Link Computers & Internet
My friend came over with her laptop and wanted to get on our network. No problem right, she entered the eight digit PIN number and was immediately connected to our network. Then when I glanced at my own...
1 if its a belkin router then open ie or firefox
2. type 192.168.2.1 in the address bar it will lead u to belkin router setup page IMPORTANT --- U NEED A HARDWIRED COMPUTER TO ACCESS THE BELKIN PAGE
3. in the belkin page on the left side click on the wifi protected setup under wireless
4. login page --- leave the password blank click submit
5. disable the wifi protected setup and click apply changes
6. then click on the channel and ssid under wireless
7. change the ssid to ur desired name thts gonna be ur network name
8. check whether the broadcast ssid is checked marked or not
9. if its checked then click on apply changes
10. then scan and connect ur network it will not ask for the pin number and u will access the internet.
Feb 06, 2010 | Computers & Internet
Friend used our pin number to access internet
You should not have given your friend your pin number. He has access to your Internet account and has locked you out.
Contact your Internet Service Provider and explain what has happened and get them to change your account login password. Then follow their instructions to setup your Belkin router.
Jul 25, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
Tew-630apb
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
87 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
