Question about Casablanca Fan Versa Touch2 W-72 Remote Control
Remote works fine for fan and uplight however, lower light goes bright then dims to off.
    Sergeant:
    Champion:
  • 342 Answers
There seems to be a problem try pressing and holding the light button see if that helps if not there is an issue with the module on the fan itself
Posted on Jan 02, 2011
Just bought a hunter remote ceiling fan with light install it just has how the manualsays it suppose to , install two 40 watt bulb turn on the fan with rrmote works fine but wen turn on lights it keep...
Make sure the toggle switch (if you have one)inside the transmitter is in the correct position for the type of bulb. Could need a new receiver. Was this one of the low-end fans sold in Home depot Or Lowes? Remember, you get what you pay for!
Aug 04, 2014 | Dryers
Hunterfan com
If you have a remote then you can't use the dimmer switch on the wall. Put in an on/off switch.
Sep 20, 2013 | Hunter 52" Ceiling Fan With Light And...
The light is very dim despite changing the light bulb and trying higher wattage light bulbs. All of the other fans in the house have good lighting and no other electrical problems in the room. The blades...
Try holding the remote light button down it has a dimmer built in it should go all the way as bright as it can go then start back down to dim.That is how mine works .
Jan 08, 2011 | Minka -Aire Brushed Nickel Remote Control...
Hi my control will completly work fofr the fan, but with the light it will only dim it and make it bright it wont turn it off from the remote, only by pulling the chain or the master switch i can turn the...
Possible that the ,main unit has a fault as the control signals are not processed. You will need to confirm your remote to be working fine specially with the light switch ON and to brighten up.
If the remote is not working check the pads of the remote.If not the fault can be the main unit possible failure of the SCR/Thyristor or a possible control unit..
Oct 29, 2010 | Hunter 52" Ceiling Fan With Light And...
Remote wont' work after changing battery
Seem like you have a bad lectronic control circuit in that fan.
Jun 29, 2009 | Oasis Hunter 54' Ceiling Fan
Lights aren't working normally
Most likely, there is a dimmer selection switch on the remote controller to dim the lights. The wall switch has no effect on the brightness.
Apr 30, 2009 | Heating & Cooling
Remote calibration
I installed three fans in the same room and one remote ran all three. In order to get the dimmers all to bring the lights up and down together, I changed the dip-switches in the fan housing so that the remote would only work one fan at a time. I then brought the dimmer lights all the way to bright. After all the lights were equally bright, I again altered the dip-switches so that all three and the remote were identical. The remote then dimmed all three lights equally.
Jun 16, 2007 | Hampton Bay AC438-VPW 52'' Vintage Pewter...
Casablanca Fan Versa Touch2 W-72 Remote Control Logo
122 people viewed this question
Top Casablanca Fan Televison & Video Experts
Steve
Are you a Casablanca Fan Televison and Video Expert? Answer questions, earn points and help others
