Question about LG RC185 DVD Recorder/VCR
My LG RC 185 will not play any DVD's - just shows message "No disc" - any ideas ??????
  • 6 more comments
  • Anonymous Oct 01, 2008
    disc will just keep spinning then says no disc detected
  • Anonymous Oct 20, 2008
    the whole DVD is not norking well - only the video.
    can't record well - can't read most of the discs....
  • BoazH Oct 20, 2008
    I have a similar problem:
    can't read almost all DVD's and the recording get stuck sometimes.
    also, since day one, the sound is not working when i connect the firewire cable...
    any idea about a FW upgrade?
  • Beret Gascon Dec 02, 2008
    I too have an LG RC185 and it's just out of warranty and it has simply stopped reading DVDs, whether pre-recorded or copies. The most common error is it just sits there with "--:--" on the screen. However, it also sometimes just ejects the disc, sits there and says "READ" or, finally, locks the DVD inside the unit so you have to do the old paper clip trick.
    Obviously the fist thing you do when you start to have read errors with a DVD is you clean the lens. I live in an old house with four dogs and two cats, so I have a lot of hair and dust that must blow around between hooverings. So, I used two different CD/DVD lens cleaners in the unit, and they made some difference but the problem persisted.
    So, I took the unit apart. 7 screws and the top cover comes off the unit. Another 4 and the DVD unit comes out. You have to unplug the power and data connectors from the DVD first. The DVD player is almost identical to a computer model except that it has different mounting brackets.
    The DVD unit comes apart easily after removing 4 small screws on top and 2 smaller on the bottom. Once open you can see everything that you could possibly clean. I blasted everything with a can of compressed air and cleaned the lens with a felt pad.
    And put it all back together again.
    And plugged it back in.
    And still the problem persists.
    I think this unit can only have buggy components. It certainly cannot be worth a repair cost. If somebody has a solution, fire away.
    Oh. You can copy pre-recorded VHS tapes onto DVD using this unit if you have a special gold cable. I'll get the details if anybody's interested.
  • arnel1947 Dec 03, 2008
    its a disaster no more no less - just as bad as KISS
    dont waste your time with this one. even LG service use standatd answer remove el. and restart.
    they should seeke somthing else to doo.
    give me a firmware that i can use
  • Anonymous Jan 20, 2009
    "no disc" error for the new DVD disc i bought.. this LG RC 185 is not detecting any DVD...plz help
  • Anonymous Mar 01, 2009
    STOPPED READING DVD,S
    EVERYTHING WAS OK FOR 1 YEAR
    NOW NO DVD IS POSSIBLE TO PLAY
  • Anonymous Apr 14, 2009
    cannot read any dvd disc. i have tried a CD-R and it worked..
  • 538 Answers
Drive needs to be replaced.
Common problem.
Posted on Mar 22, 2009
  • pontelemon
    pontelemon Mar 22, 2009
    Common problem.
Can I get Parts for LG RC185
I agree with Robert - best option is to get the loader unit from LG Spares directly, then swop it yourself. If you are familiar with swopping HDD's/DVD units in PC's then it's easy to swop the loader unit ;-)
Feb 04, 2015 | LG RC185 DVD Recorder/VCR
How can I transfer my vhs tapes to dvd from the LG RC185?
I think you use the "dubbing" button. I would strongly suggest reading the user manual for the specific step-by-step procedure as this is an integrated unit (see page 39 of the below link "Copying from VCR to DVD") - unfortunately LG's own site chooses no to use PDF and you need to install a plugin, so I suggest you download a PDF copy from doocument.com here: http://doocument.com/pdf/dvd-recorder-video-cassette-recorder-produktinfo-34042.pdf
May 31, 2014 | LG RC185 DVD Recorder/VCR
After 5 years of playing region 2 DVD's machine comes up with "incorrect region code" and ejects
  1. Open the disc tray
  2. (Press SETUP and scroll to 'Lock')
  3. Press 0 seven times
  4. (Press ENTER, Setup)
Mar 01, 2011 | LG RC185 DVD Recorder/VCR
Returns error message :Unknown Disc. Please Check Disc Again" The DVD disc plays on other DVD players with no problem.
Problem may be reset needed, or lens need cleaning, or dvd recoreder worn out. Reset is pull the plug from the wall for 5 minutes. Turn it back on after reset to load firmware again, may work after that.. TDK makes lens cleaner. LG uses fan so, dirt can get into dvd recorder lens. If the tray moves out wiggly, laser assembly may move wiggly too. Replace dvd recorder which is a dvd+-rw regular ide unit from computers.
Aug 20, 2010 | LG RC-197 DVD Recorder/VCR
Dvd lg rc185 only HELLO
Does a powercycle solve it? I had the same issue and after powering the device off for approx 10 seconds all worked fine
Apr 06, 2009 | LG RC185 DVD Recorder/VCR
LG RC185 DVD Recorder/VCR Logo
527 people viewed this question
Computer Repairing
Computer Repairing
