Question about Citizen Blue Angels Skyhawk Watch
SETTING TIME - Citizen Blue Angels Skyhawk Watch
THIS PRODUCT IS AN EVERFLOURISH TIMER. HOW CAN I ADJUST THE ACTUAL TIME ON THIS TIMER.
I suggest you email them direct for this and also for the manual at
efnb@everflourish.com.cn but it does sound like you have it and look at # 2, after setting the day, you set the time:
2. Time Setting 2.1 After setting the day of the week, hour display flashes to indicate setting time can be started 2.2 Press +Button to increase number of hour, or Button to reduce hour. 2.3 Press +/ Button once will increase or reduce each hour slowly. To press and hold the button, the hour display moves quickly. Release the button until your desired hour shown on the display. Press SET Button to confirm your setting. 2.4 “Minute” display then flashes to indicate setting minute is ready. Repeat the same procedures in setting hour as in #2.2 and #2.3 to set minutes.
manual here:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&sqi=2&ved=0ahUKEwii9O-RtrTMAhVKgiYKHRULDsgQFggjMAE&url=http%3A%2F%2Fproduktinfo.conrad.com%2Fdatenblaetter%2F600000-624999%2F616021-an-01-en-Mini_Zeitschaltuhr_digital.pdf&usg=AFQjCNGYADTAgA9msCpN4otTAxRQ1PJ6dA&bvm=bv.120853415,d.cWw
Apr 29, 2016 | Watches
How to set the time on an adidas sports watch ADP6034
1.
In time mode, press and hold A for 2 seconds to enter time setting.
2.
Press C to increase setting value. Press D to decrease setting value.
3.
Press B to enter next setting field.
4.
Press pusher A to exit setting mode.
From Left top button A and following B & right top C & D bottom.
Dec 27, 2012 | Watches
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
Mar 01, 2012 | Timex 1440 Nylon watch
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
I just bought a watch its number is ADH4017 i believe its the peach tree watch,something like that. its neon yellow, anyway i cant find the settings to change the time. can somebody please help me i...
TIME/CALENDAR SETTING
1. In normal time display, press and hold A to enter setting mode; chime will begin
flashing.
2. Press C to increase setting value. Press D to decrease setting value.
3. Press B to set and advance to next setting value.
4. Setting sequence is chime, 12/24-hour time, hour, minute, second, year, month,
date, Auto EL.
5. Press A to save data and exit setting mode.
Dec 02, 2010 | Adidas Unisex Watch Wooster ADH1770 - WW
How do you set this watch....4 buttons
SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
Jul 26, 2010 | Fossil JR9455 Watch
Tozai digital watch-setting correct time/date
I need to correct the time/date setting on a tozai digital watch.
Apr 05, 2009 | Watches
Sportline watch setting time???
With the watch in time mode, press and hold the mode button for 4 to 5 seconds until it beeps and the digits start to blink. Then press the mode button again to advance through each setting. When finished press and hold the mode button to exit the setting mode.
Mar 15, 2008 | Sportline 1000 Memory watch
Citizen Blue Angels Skyhawk Watch Logo
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
