Question about Kenmore Vacuums
The bobbin in my Kenmore 28 model #385 17928090 sewing machine is knotting up and will jam up. It has been working fine until now.
5 Suggested Answers
HansPP
  • 2510 Answers
SOURCE: Thread and bobbin both threaded
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Posted on Mar 16, 2011
  • 4 Answers
SOURCE: i need kenmore 385 1168280
The Kenmore website (www.kenmore.com) has manuals available for all of there sewing machines. At the top of the page hold your mouse over the product support section. From there a drop menu will come down that has the link to the manuals portion of the website. Hope this helps.
Posted on May 07, 2011
joeguest2
  • 2080 Answers
SOURCE: I have a Kenmore sewing
Here is a direct link to the Owner's Manual for your machine:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0411039.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
If you choose to rate this solution by clicking on the YES THIS WAS HELPFUL icon, I thank you very much for your time and consideration.
Joe.
Posted on Aug 07, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Can not locate my manuel
Hi rose13olive...
Go to the following webpage and download your user manual for your sewing machine.
Please take time to rate me
http://search-pdf-books.com/kenmore-sensor-sew-70-model-385-sewing-machine-users-manual-pdf/
Posted on Aug 16, 2011
The pile up of top thread
Is this in embroidery mode or sewing mode? It may be the top tension is off (in my experience knots on bottom is bobbin issue, knots on top is upper tension issue).
Sep 30, 2012 | Singer Futura CE-250
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
Thread and bobbin both threaded properly, but bobbin thread keeps knotting. sewing at top looks great but bobbin side is just knots!! I have a Euro-pro sewing machine.
Mar 16, 2011 | Vacuums
I have a computerized Kenmore 150 the model # is 385. 19150090 and the serial # is 31001565 the problem is every time you turn it on it says overload and it will not do anything any sugestions? or what...
This happened to me too. I was using the wrong bobbins and when I would try to sew, the bobbin would slide up and down. I switched to a Kenmore bobbin and my machine hasn't given me any more trouble.
Jan 25, 2011 | Kenmore Vacuums
I have a model 605d ,the machine work fine except it will not sew! i look over the machine it look ok ! i am found out that top spool thread and the bottom bobbin thread are not coming together to sew!
You have to do the first stitch using the handwheel so that the top thread catches under the bobbin thread and then you can pull the top thread which will bring up the bobbin thread. put both threads to back of machine. Now you can sew.
Every time you re-thread you need to do this.
Dec 21, 2010 | Vacuums
Kenmore YM-40-35 R Sewing Machine Manual (or copy) wanted. If a manual is not available, I'd be OK with instructions for threading the needle and bobbin and any additional details that an expert may...
Please go through the below document which will give you the help you wanted:
http://www.ehow.com/how_4798790_thread-bobbin-kenmore-sewing-machine.html
http://www.ehow.com/how_5839_thread-sewing-machine.html
http://www.youtube.com/watch?v=1j8e8FvwUlQ
You will also find additional information on every page at the left hand side (Ehow.com) and on the right hand side(Youtube).
Please let me know if you need any additional information or have any information that you would like to share with me.
Jun 10, 2010 | Vacuums
While using the pin stitch , the machine has started skipping stitches, knocking loudly, the top thread is breaking, sometimes thread knots up on the underneath side. I have cleaned bobbin area, changed...
Please go through the link given bellow to have the resolution to your problem...
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Apr 27, 2010 | Vacuums
Vacuums Logo
314 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
