Question about Kenmore Kitchen Ranges
E-1 F-3 |Oven won't start. |Have unlocked it but still don't start
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
F3 E1 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jan 03, 2011
How to remove oven thermostat on whirlpool stove
You don\'t need to remove the top. The thermostat is the long skinny tube in the oven that comes up to the railcock behind the oven control knob, remove the front panel to get the railcock/thermostat out which has the tube attached to it.
Mar 20, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Microwave snot statrting
Hi it sounds like a bad door switch, cause they are so dangerous ,it won't let it run cause it thinks the door is open . they have safty door switches , If you don't know much about electricity don't go inside a microwave
Dec 05, 2011 | KitchenAid Architect® KEMS308SSS Stainless...
My phone won't send messages I got credit and still won't. also Mob internet don't work
You Can Unlock Your HTC Desire . Call Your Network Provider To Ask Your HTC Phone Unlock Code. But your Network Provider Takes Time To Give You Unlock Code.
If You Want Your Imei Unlock Code Instantly. Buy HTC Imei Unlock Code From Third Party. Many Site Available Online To Provide Imei Unlock Code.
I Hope This Will Help You.
Thank's
Oct 05, 2011 | HTC Desire Cell Phone
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
How do I start the self cleaning? I hit clean and it does not start
On most self-cleaning ovens after you push the clean cycle button you have to tell it how long you want it to clean. Try pushing clean then pushing 3:00 for 3 hrs. If you don't have a number pad try pushing the clean pad several times and see if it cycles through clean levels like low, med or high. Then after you tell it how long to clean hit start. If you don't have a start button the oven should start cleaning after around 5 seconds. It will lock the door and begin the clean cycle. Also remember it takes around an hour for the oven to cool and unlock after the cycle is finished. Hope that helps.
Aug 29, 2011 | GE JKP45 Electric Double Oven
The oven door won't unlock even though self-cleaning has been cancelled
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Aug 10, 2011 | Frigidaire FEB27T5D Electric Double Oven
Viking oven gets warm but not real hot. The coil does not get red and appears to be not working
Typically the problem is with the oven controller. IF your RTD (resistive temperature device) is ok then your oven controller board is faulty. When the oven is turned on (bake mode) the oven controller closes the relay that controls the bottom element and the oven begins to heat. The RTD or thermostat provides a feedback loop to the oven controller. RTDs don't partially fail, they either work or they don't. Since your oven is getting warm I would imagine the RTD is okay. You can verify the RTD by measuring its resistance at room temperature. Remove power from the oven and either remove the RTD completely and measure with an OHM meter or remove leads and measure while still attached to the oven chassis. You may have to remove it if your ohm meter leads won't reach. I don't know your model oven but most RTDs at room temp are about 1.1 kohms or 1100 ohms. If this is the case your RTD is fine and your controller board is bad. Please let me know if you need anything else. Good luck!
Jul 02, 2011 | Viking Kitchen Ranges
Oven door lock does not unlock, I turned on the self clean mode and then changed my mind and turn it back off about 3 minutes later. But it does not unlock. The lock light is blinking.
Hi
Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch might solve the issue.
To reset it: Turn off the power. Open the door (if door is locked, turn the power back on and gently try pulling the door every few seconds as the locking mechanism cycles until it is unlocked). Remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven). Pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 26, 2009 | Electrolux E30DF74PS Dual Fuel (Electric...
Kitchen Ranges Logo
134 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
